Posted: Thu Dec 29, 2011 5:45 am |
Has anyone replaced just the bottom Ball Joint on their 206?
We have just replaced the complete A-arm.
and used a superb post by 'Ape' on replacing the A-arm
Both bushes on the old A-arm look fine but we were thinking of replacing the old ball joint and keeping the old A-arm as a spare
On our old Saxo the Ball Joint was easy to replace.....with a couple of sockets and a vice
Is it the same method on the 206?
Posted: Thu Dec 29, 2011 6:09 am |
You need to replace the whole arm.
Posted: Thu Dec 29, 2011 10:33 am |
don't think you can.
and that's why you should get a decent wishbone. The ball joint tends to be the first thing to split on the cheap stuff
Posted: Thu Dec 29, 2011 10:36 am |
Seabook wrote: |
and that's why you should get a decent wishbone |
Genuine Peugeot part's everytime, saves money in the long run
Posted: Thu Dec 29, 2011 11:06 am |
I used lemforder on my 206, so far they have been fine
Posted: Thu Dec 29, 2011 12:29 pm |
I have seen them separately on ebay but you probably need a press or something to put them in.
