Latest: heikkisj
Overall: 17126
Online Now [38]:
Visitors: 37
Today: 9816
Total: 100342828
Forums › The Car › 206 Problems › low response on 1.4e 206
marko.rebric
PostPosted: Thu Dec 29, 2011 9:20 am Up
Hi guys, I'm new at this forum, and I registered to see what you guys think about my problem.
Anyway, I own 1.4i 75hp 206, produced in 2006.
Problem is, when I start the car, I hit the gas pedal and instead of making revs go higher, engine first makes them lower! So it goes like this: I start the engine, wait for a few seconds, then just for a brief moment I hit the gas and release it, and revs first go down (for, say, 150rpm) and THEN go up without problem. In some cases, if I hit the gas for too long, engine goes off! (when engine's cold)
Besides that, engine's responding too late in casual driving.. It's like it is hesitating.
My regular garage-man told me that perhaps it could be lambda sensor... Other than that, he has no clue. (no problems found on diagnostics whatsoever).
And I have found out that cleaning of stepper motor, throttle body and MAP sensor may help !!?? And maybe, ECU update..?
So, what do you guys think of it ?
... lion is the king too, but it doesn't make him live longer...
www.youtube.com/watch?v=RLlgmRe2mG0
Andrew
PostPosted: Thu Dec 29, 2011 10:02 am Up
Does your engine have an electric throttle body? If so, you will not have a idle control valve
My 206 thread
www.detailedbyandrew.com
marko.rebric
PostPosted: Thu Dec 29, 2011 10:21 am Up
I'm not quite sure what makes throttle body electric, but I have "drive by wire" if that's what you mean...
PostPosted: Thu Dec 29, 2011 10:26 am Up
Then you have an electronic throttle body Wink
PostPosted: Thu Dec 29, 2011 10:28 am Up
ECU needs updating.
marko.rebric
PostPosted: Thu Dec 29, 2011 10:32 am Up
Yes Lee, I've seen what you did here www.206info.co.uk/Foru...39062.html .
But can it be that simple? And what's the real cause of the problem?
PostPosted: Thu Dec 29, 2011 10:40 am Up
A software bug in the engine ecu.
Peugeot main dealer time & get the software updated Wink
Rob2859
PostPosted: Thu Dec 29, 2011 11:11 am Up
A mate of mine had a Clio with a similar issue. It had an electronic throttle and would only rev down until it stalled. Cable all the way.
PostPosted: Thu Dec 29, 2011 11:16 am Up
Nothing wrong with fly by wire throttles if the software is written correctly.
Rob2859
PostPosted: Thu Dec 29, 2011 11:22 am Up
Chances are cable is not going to fail though and its more responsive from what I have heard. Also its harder to identify a noise when you can't adjust the throttle from the engine bay.
marko.rebric
PostPosted: Thu Dec 29, 2011 4:08 pm Up
So, the bottom line is ECU update...? But cleaning other things I mentioned would do no harm ? Very Happy
Andrew
PostPosted: Thu Dec 29, 2011 4:46 pm Up
Yes, I had a similar problem, visit to main dealer for an update and it was solved
My 206 thread
