Online Now [727]:
Visitors: 726
Today: 119475
Total: 157425027
Forums › The Car › 206 Talk › Engine weight difference
Forum Index › 206 Talk
HDI90
PostPosted: Thu Dec 29, 2011 11:04 am Up
Im just after the weight difference between a 2.0 petrol and diesel, as ive just got hold of some 25mm eibach springs and shocks from a GTI
so in theory if the diesel has more weight the car will be lower than the 25mm?
GTI 180
Mattie-RS
PostPosted: Thu Dec 29, 2011 11:08 am Up
the diesel is the heavier
PostPosted: Thu Dec 29, 2011 11:11 am Up
What He Said
think the EW10 is aluminium block while the DW10 is cast iron block
Rob2859
PostPosted: Thu Dec 29, 2011 11:12 am Up
I wouldn't expect a big difference. Remember the springs need quite a while to settle too.
PostPosted: Thu Dec 29, 2011 11:18 am Up
Mine didn't settle ever. Lowered it exactly 30mm and stayed there.
The Pro Kit springs are for the 1.4HDi and GTi aren't they?
HDI90
PostPosted: Thu Dec 29, 2011 11:22 am Up
Yes but the ones i got are for the GTI
GTI 180
PostPosted: Thu Dec 29, 2011 12:25 pm Up
decent spring shall not take time to settle Confused
PostPosted: Thu Dec 29, 2011 12:28 pm Up
Some EW10 are cast other are alloy
PostPosted: Thu Dec 29, 2011 12:30 pm Up
when did they change over? Shocked
Mattie-RS
PostPosted: Thu Dec 29, 2011 12:31 pm Up
basically your going to get 27mm if that!!
PostPosted: Thu Dec 29, 2011 12:32 pm Up
I'll try and have a look, might be the whole RFN/RFR thing. Off the top of my head the serial number is in a different place on the alloy to the cast
PostPosted: Thu Dec 29, 2011 12:47 pm Up
All EW10 engine are alloy. RFN/RFR just means the addition of a 2nd lambda sensor.
PostPosted: Thu Dec 29, 2011 1:04 pm Up
I've definitely read on servicebox some are alloy and some are cast.
