Posted: Thu Dec 29, 2011 11:04 am |
Im just after the weight difference between a 2.0 petrol and diesel, as ive just got hold of some 25mm eibach springs and shocks from a GTI
so in theory if the diesel has more weight the car will be lower than the 25mm?
Posted: Thu Dec 29, 2011 11:08 am |
the diesel is the heavier
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
Posted: Thu Dec 29, 2011 11:11 am |
| Mattie-RS wrote: |
| the diesel is the heavier |
think the EW10 is aluminium block while the DW10 is cast iron block
Posted: Thu Dec 29, 2011 11:12 am |
I wouldn't expect a big difference. Remember the springs need quite a while to settle too.
Posted: Thu Dec 29, 2011 11:18 am |
Mine didn't settle ever. Lowered it exactly 30mm and stayed there.
The Pro Kit springs are for the 1.4HDi and GTi aren't they?
Posted: Thu Dec 29, 2011 11:22 am |
| Edward wrote: |
The Pro Kit springs are for the 1.4HDi and GTi aren't they? |
Yes but the ones i got are for the GTI
Posted: Thu Dec 29, 2011 12:25 pm |
| Rob2859 wrote: |
| I wouldn't expect a big difference. Remember the springs need quite a while to settle too. |
decent spring shall not take time to settle
Posted: Thu Dec 29, 2011 12:28 pm |
Some EW10 are cast other are alloy
Posted: Thu Dec 29, 2011 12:30 pm |
| Lee wrote: |
| Some EW10 are cast other are alloy |
when did they change over?
Posted: Thu Dec 29, 2011 12:31 pm |
basically your going to get 27mm if that!!
Posted: Thu Dec 29, 2011 12:32 pm |
I'll try and have a look, might be the whole RFN/RFR thing. Off the top of my head the serial number is in a different place on the alloy to the cast
Posted: Thu Dec 29, 2011 12:47 pm |
All EW10 engine are alloy. RFN/RFR just means the addition of a 2nd lambda sensor.
Posted: Thu Dec 29, 2011 1:04 pm |
I've definitely read on servicebox some are alloy and some are cast.
