Posted: Thu Dec 29, 2011 8:44 am |
Hi Guys,
As per subject title. I have a Peugeot 206 1.4 GLX and there is water dripping from the exhaust system between the manifold and the middle pipe. Do I need to replace the clamp or gasket as I was just told to replace the olive which does not make major sense???
Posted: Thu Dec 29, 2011 4:23 pm |
If its a ball joint type thing then its just an olive with a boly holding it tight, I believe some connect with a flat gasket type connection.
thats bolt, not boly
Posted: Fri Dec 30, 2011 5:20 am |
Thanks for the info mate, will get sorted.
