Online Now [1257]:
Visitors: 1256
Today: 195759
Total: 155285156
Forums › The Car › 206 Talk › 206 gti cams ... will they fit in my 1.6 16v and still run?
Forum Index › 206 Talk
tailhappy
PostPosted: Thu Dec 29, 2011 9:52 pm Up
i have been thinking of doing what vauxhall lovers do and upgrade the cam to 1 of a bigger engine but am not sure if this will work on a pug HELP!!??
jamie bennett
jayz206gti
PostPosted: Thu Dec 29, 2011 10:43 pm Up
They are two different engines so if you want to throw the timing out and either break it or make it run like a pig id suggest just looking for a set of uprated ones for the 1.6? Just an idea...
Upgraded from 138 to 180
PostPosted: Fri Dec 30, 2011 3:23 am Up
Quite simply they won't fit.
HDI90
PostPosted: Fri Dec 30, 2011 3:35 am Up
Gone of the days of swaping cams from cars, you used to be able to do it with the old ford CVH and vauxhall 8v engines . but like edward said no
GTI 180
PostPosted: Fri Dec 30, 2011 4:41 am Up
You can buy mine and try though Laughing
Andrew
PostPosted: Fri Dec 30, 2011 5:45 am Up
Take a read of this: c2club.co.uk/showthrea...ur-Options
The 1.6 16v in the C2s are the same as your engine. Yours is slightly 'detuned' and I'm guessing the difference is the head and the cams, so maybe using ones from a 106 gti or maybe a whole C2 VTS head you might have something to gain - I am not sure if a C2 VTS headswap requires anything else or not though
My 206 thread
www.detailedbyandrew.com
PostPosted: Fri Dec 30, 2011 7:18 am Up
normally people run saxo cam, C2 inlet and saxo manifold
this would be the budget option
tailhappy
PostPosted: Sat Dec 31, 2011 3:04 am Up
i have been told by TJH motorsport that the C2 head is the port and polished equivelent of mine but i will be swapping ... thanks guys Very Happy
jamie bennett
PostPosted: Sat Dec 31, 2011 4:22 am Up
are you sure he is talking about C2 VTS, not C2 R2?
the VTS one as far as i know they are similar to 206.
PostPosted: Sat Dec 31, 2011 9:12 am Up
Why not just match port and polish yours? Laughing
tailhappy
PostPosted: Mon Jan 02, 2012 12:06 am Up
because mine is slightly down on compression atm from when my cam belt snapped so i need a new head anyway
jamie bennett
