Posted: Thu Dec 29, 2011 9:52 pm |
i have been thinking of doing what vauxhall lovers do and upgrade the cam to 1 of a bigger engine but am not sure if this will work on a pug HELP!!??
Posted: Thu Dec 29, 2011 10:43 pm |
They are two different engines so if you want to throw the timing out and either break it or make it run like a pig id suggest just looking for a set of uprated ones for the 1.6? Just an idea...
Posted: Fri Dec 30, 2011 3:23 am |
Quite simply they won't fit.
Posted: Fri Dec 30, 2011 3:35 am |
Gone of the days of swaping cams from cars, you used to be able to do it with the old ford CVH and vauxhall 8v engines . but like edward said no
Posted: Fri Dec 30, 2011 4:41 am |
You can buy mine and try though
Posted: Fri Dec 30, 2011 5:45 am |
Take a read of this: c2club.co.uk/showthrea...ur-Options
The 1.6 16v in the C2s are the same as your engine. Yours is slightly 'detuned' and I'm guessing the difference is the head and the cams, so maybe using ones from a 106 gti or maybe a whole C2 VTS head you might have something to gain - I am not sure if a C2 VTS headswap requires anything else or not though
Posted: Fri Dec 30, 2011 7:18 am |
normally people run saxo cam, C2 inlet and saxo manifold
this would be the budget option
Posted: Sat Dec 31, 2011 3:04 am |
i have been told by TJH motorsport that the C2 head is the port and polished equivelent of mine but i will be swapping ... thanks guys
Posted: Sat Dec 31, 2011 4:22 am |
are you sure he is talking about C2 VTS, not C2 R2?
the VTS one as far as i know they are similar to 206.
Posted: Sat Dec 31, 2011 9:12 am |
Why not just match port and polish yours?
| Team Impossible Possible
Posted: Mon Jan 02, 2012 12:06 am |
because mine is slightly down on compression atm from when my cam belt snapped so i need a new head anyway
