Latest: Makomeister18274
Overall: 17122
Online Now [78]:
Visitors: 77
Today: 5431
Total: 97816012
Forums › The Car › 206 Problems › the problems go on and on
DavidPCoates
PostPosted: Fri Dec 30, 2011 10:00 am Up
after doing the head twice on my 206 it then ran awful, this was tested and found 2 injectors were faulty, changed and all ok.
BUT
Now the temperature gauge only moves up the dial a little, was told ah ha thats the thermostat, so for the great expence of £9 i got and fitted another, low and behold its still not moving!!!! Any ideas???
Dave Exclamation
Dave Coates
PostPosted: Fri Dec 30, 2011 10:01 am Up
Coolant temp sensor working correctly?
DavidPCoates
PostPosted: Fri Dec 30, 2011 10:03 am Up
how would i check it, and why would it break?
Dave Coates
AshH
PostPosted: Fri Dec 30, 2011 10:07 am Up
Because its French :/ Laughing
Team - 180
Team - ATM!!!
PostPosted: Fri Dec 30, 2011 10:08 am Up
Coolant temp sensor is a known failure point on the TU engines.
You should be able to check when the thermostat opens as the temp dial gets to just under 90 deg C, the top radiator hose should get hot as the coolant starts to pass through to flow in to the rad.
Where did the new thermostat come from?
Genuine Peugeot / Citroen thermostat just under £10, fitted it last week on my TU3 Very Happy
DavidPCoates
PostPosted: Fri Dec 30, 2011 10:14 am Up
new thermostat, from gsf.
i guess there isnt anything else left, im assuming the new thermostat is ok, next guess would be switch.
Dave Coates
PostPosted: Fri Dec 30, 2011 10:16 am Up
Search for a post I made, I listed the ohms reading that the ECT should give out at different temps.
Also listed the voltage for the pin out of the ECU I think.
DavidPCoates
PostPosted: Fri Dec 30, 2011 10:41 am Up
I am right it is the green connector on the top of the head, right hand side as you look at it.
Dave
Dave Coates
PostPosted: Fri Dec 30, 2011 10:46 am Up
Correct
