Posted: Fri Dec 30, 2011 10:00 am |
after doing the head twice on my 206 it then ran awful, this was tested and found 2 injectors were faulty, changed and all ok.
BUT
Now the temperature gauge only moves up the dial a little, was told ah ha thats the thermostat, so for the great expence of £9 i got and fitted another, low and behold its still not moving!!!! Any ideas???
Dave
Posted: Fri Dec 30, 2011 10:01 am |
Coolant temp sensor working correctly?
Posted: Fri Dec 30, 2011 10:03 am |
how would i check it, and why would it break?
Posted: Fri Dec 30, 2011 10:07 am |
DavidPCoates wrote: |
how would i check it, and why would it break? |
Because its French :/
Posted: Fri Dec 30, 2011 10:08 am |
Posted: Fri Dec 30, 2011 10:14 am |
new thermostat, from gsf.
i guess there isnt anything else left, im assuming the new thermostat is ok, next guess would be switch.
Posted: Fri Dec 30, 2011 10:16 am |
Search for a post I made, I listed the ohms reading that the ECT should give out at different temps.
Also listed the voltage for the pin out of the ECU I think.
Posted: Fri Dec 30, 2011 10:41 am |
I am right it is the green connector on the top of the head, right hand side as you look at it.
Dave
Posted: Fri Dec 30, 2011 10:46 am |
Correct
