Online Now [53]:
Visitors: 52
Today: 94725
Total: 117344587
Forums › The Car › 206 Problems › Single beep from car when starting up
Go to page Previous  1, 2, 3
PostPosted: Fri Dec 30, 2011 8:53 am Up
PaddyC wrote:
There is no light on the dash, it's only on the new MFD. I wonder what the beep is if it isn't the ABS. Is there any way of getting it stopped, maybe a system reset or something?
Does your car actually have ABS fitted?
PostPosted: Fri Dec 30, 2011 9:31 am Up
Is the battery flat on the car?
gixxerkev
PostPosted: Fri Dec 30, 2011 10:12 am Up
Thread Hi-jack: So is a PPT-40 a double line display because mines a PPT-40 and it only has a single line? Whats the part number for a double line display and can it be fitted to a 2003 1.4 GLX?
An Ex '03 1.4 GLX driver, German technology all the way now.
PostPosted: Fri Dec 30, 2011 10:15 am Up
PPT-40 is just the connector for a multiplexed MFD
gixxerkev
PostPosted: Fri Dec 30, 2011 10:21 am Up
So I take it that there isn't a double line display that'll fit my car then?
PostPosted: Fri Dec 30, 2011 10:23 am Up
You need a PPT 40 - 3 line display, got one in my 03 plate GLX.
gixxerkev
PostPosted: Fri Dec 30, 2011 10:28 am Up
My display says PPT-40 on it but Lee says thats just for the connector, so there must be a 2 line display that'll fit then. Ebay here I come.
PostPosted: Fri Dec 30, 2011 10:30 am Up
That is correct, PPT 40 is just the connector plug.
My original single line display had PPT 40 on it, my replacement 3 line display also had PPT 40 on it Laughing
gixxerkev
PostPosted: Fri Dec 30, 2011 10:42 am Up
Thanks Mr BSI, Ive found one on eBay and messaged the seller to see if it has PPT40 on it. I read somewhere you need a button on a stalk to change the display, my wiper has a button that sets the lights and wipers to auto but will it change the display?
PostPosted: Fri Dec 30, 2011 10:45 am Up
Not unless the original com has been changed.
Will be << on the end of the wiper stalk for trip computer, you can on some com units remove the end of the wiper stalk & you should find the little switch is hidden inside, you then just have to get another com end with the push button fitted.
gixxerkev
PostPosted: Fri Dec 30, 2011 10:49 am Up
The original COM was replaced earlier this year but I think the new one has << on the wiper end, Ill check tomorrow. I think getting a 3 line display could be a non starter though, sounds like its getting too complicated.
Thanks again.
PostPosted: Fri Dec 30, 2011 10:55 am Up
Thanks again.
Display just plugs straight in & works.
If you want the trip computer features working to, thats when you need the extra button on wiper stalk.
jcowan
PostPosted: Fri Dec 30, 2011 7:45 pm Up
03 plate 1.4 lx, i must only have the single line display, however im positive there is a button already on my wiper stalk so hopefully it should be pretty straightforward if i decide to change it but before i do can somebody that has a 2 or 3 line display stick a pic up for me to see if i think its worthwhile, be greatly appreciated cheers.
2003 1.4 LX Silver.
PaddyC
PostPosted: Sat Dec 31, 2011 3:55 pm Up
I am not sure if mine has ABS fitted but I'm sort of sure it does, how can I check?
I have taken the push button of the auto lights stalk and put it on the other one for the wipers so now can change the display to show whatever I want, and I put the non push one on the light stalk. I then reset the whole thing by holding in the button on the wiper stalk for 3 seconds. Since then, I have not had the beep for the ABS fault and my lights and central locking have been working perfectly since. Typical, I also ordered the newCom Unit but may not even need it! Might as well fit it anyway!
Peugeot 206 1.4HDI Style
Page 3 of 3
