Latest: Puggingalong
Overall: 17129
Online Now [39]:
Visitors: 38
Today: 52359
Total: 100721702
Forums › The Car › 206 Problems › Gti 140 brake issue
Gti 140 brake issue
rick-gti
PostPosted: Sat Dec 31, 2011 6:41 am Up
Hi guys, my brake pedal on my gti has been spongy.
I have just changed the brake fluid and bled the brakes and they still feel abit spongy. All calipers are ok and pipes. Do the gti's have much pedal travel?
clio 197sport owner
PostPosted: Sat Dec 31, 2011 6:46 am Up
Checked the condition of the pads? You'll get more travel if they are worn.
rick-gti
PostPosted: Sat Dec 31, 2011 7:23 am Up
Pads and discs are all ok.
clio 197sport owner
PostPosted: Sat Dec 31, 2011 7:28 am Up
206 brake are always spongy
Abzynthe
PostPosted: Sat Dec 31, 2011 7:30 am Up
East Area Rep - Abzynthe
I agree, both of mine are a bit spongy, but the brakes still work. You get used to it after a while.
rick-gti
PostPosted: Sat Dec 31, 2011 8:07 am Up
If they are all abit spongy then the braking system isnt that good. Would fitting 180 or gti6 front brakes make much difference?
clio 197sport owner
PostPosted: Sat Dec 31, 2011 8:37 am Up
They all have a soft pedal regardless of what calipers are fitted.
PostPosted: Sat Dec 31, 2011 9:06 am Up
Drove a 54 plate Mondeo earlier in the week, always feels odd getting back in to the 206 afterwards at how heavy the clutch & steering is & how spongy the brake pedal feels.
rick-gti
PostPosted: Sat Dec 31, 2011 9:32 am Up
I had 8 pot k sport brakes with 385mm discs on my subaru which had amazing stopping power. Must just be me not used to a poor brake system. Although I had 2 gti6's and the brakes on both of them were ok compared to my 206 gti. So there isnt a problem with the brakes its normal for there to be some travel in the pedal then.
clio 197sport owner
PostPosted: Sat Dec 31, 2011 9:37 am Up
306 the master cylinder is connected directly to the brake pedal on right hand drive.
Right hand drive 206 the brake pedal isnt, there is the transfer rod linkage behind the dash to as the master cylinder is on the other side of the engine bay.
PostPosted: Sat Dec 31, 2011 10:04 am Up
Get some braided hoses, thats supposed to improve the feel.
PostPosted: Sat Dec 31, 2011 10:05 am Up
Not by much Wink
Im glad I got discount on mine Laughing
PostPosted: Sat Dec 31, 2011 10:17 am Up
Yeah, but personally I still think its a worthwhile investment Wink
PostPosted: Sat Dec 31, 2011 10:20 am Up
Id wait till the standard hoses want replacing.
PostPosted: Sat Dec 31, 2011 10:25 am Up
I suppose, they are only £8-£9 each Smile
