Online Now [536]:
Visitors: 535
Today: 134239
Total: 155089211
Forums › The Car › 206 Problems › Severe power loss...sounds like a tractor 1.4 8v
Go to page 1, 2, 3  Next
GLX_laney
PostPosted: Sun Jan 01, 2012 5:16 am Up
Hi Guys,
Wondering if you could help me... I dropped a friend into town late last night. As i left the city centre, the car began to shudder vigorously in lower rpm's, but as the rpm's got higher, the shudder remained there but was less.
The shudder stopped when pressing the clutch in, something to do with a gearbox possibly? Also, the idle is pretty rough, as if it's coughing and spluttering. There's also a bit of a shake when it's idling in neutral.
I popped the bonnet when i got home and the engine sounded pretty rattley on idle. When revving, (this is the best way i can describe it) it literally sounds like it has a cold!
What can i do? Thanks for taking the time to read!
(Keep in mind, this is my first car. I don't know the first thing about anything to do with motoring! Embarassed )
Thanks!
Neil
I.C.E killed my car.
PostPosted: Sun Jan 01, 2012 5:31 am Up
Pull your spark plugs out see of 1 or 2 are dirtier than others, I had something similar happen to mine, turned out to be the coil pack.
Abzynthe
PostPosted: Sun Jan 01, 2012 5:34 am Up
East Area Rep - Abzynthe
Coil pack or head gasket?
GLX_laney
PostPosted: Sun Jan 01, 2012 5:46 am Up
It's in my garage now, how can i access the spark plugs guys?
Abzynthe
PostPosted: Sun Jan 01, 2012 5:49 am Up
Take the coil pack off and they are underneath
GLX_laney
Is that coil pack the bit just above the silver rocker cover wotsit?
Abzynthe
PostPosted: Sun Jan 01, 2012 5:51 am Up
Its the black plastic strip thing behind the rocker cover Smile
GLX_laney
PostPosted: Sun Jan 01, 2012 6:22 am Up
How do you check the spark plugs then mate? It looks like even if you take the coil pack out, it's still a ballache to get to the plugs?
PostPosted: Sun Jan 01, 2012 6:25 am Up
Remove them with the correct sized spark plug socket.
GLX_laney
PostPosted: Sun Jan 01, 2012 7:49 am Up
Thanks guys. Have just purchased a Haynes manual, along with your advice i think i know what i'm doing now, for once! Very Happy
Will keep you updated. Work begins after a bacon sarnie!
GLX_laney
PostPosted: Sun Jan 01, 2012 8:46 am Up
UPDATE
Have finished with it for now! I put everything back together, the spark plugs seemed difficult to get out, so they must have been in fine. Maybe one isn't working right?
Would it be worth replacing them, as they seem fairly clean considering?
-Dave-
PostPosted: Sun Jan 01, 2012 9:11 am Up
Trade Rating: +36
Don't take this the wrong way but as this is your first car and you don't know what to look for my advice would be take it to a local garage and get them to check over it for you. But as they do it ask them to explain and show you. That way you learn at the same time do next time you know what your looking at.
Ex 206 Owner.
GLX_laney
PostPosted: Sun Jan 01, 2012 11:38 am Up
Thanks mate. I have a friend who works for a well established garage down here. He pulled out all of the spark plugs and said they looked fine. he cleaned them off with a wire brush and re-inserted them. He seems to believe that the coil pack is on its way out. Would this be likely?
PostPosted: Sun Jan 01, 2012 4:22 pm Up
As i said same with mine, i had 2 that went black from unburnt fuel as i did limp it around a bit.
pug-206-boy
PostPosted: Sun Jan 01, 2012 4:59 pm Up
it could possibly be an injector...
the same thing happened to me once..turns out one of the injectors clogged up...worth a thought? :/
Page 1 of 3
