Latest: heikkisj
Overall: 17126
Online Now [202]:
Visitors: 201
Today: 29338
Total: 100362294
Forums › The Car › 206 Problems › ABS Light Comes On.... But Only At Speed
Martind
PostPosted: Tue Jan 03, 2012 5:18 am Up
Hi All,
Bit of an Odd one here...
My car runs as it should most of the time, with no warning lights showing (touch wood it continues that way!)
Until you hit high motorway speed, then the ABS light comes on and stays on until.... Well, until it feels like going off!
Turn Ignition Off, then back on and drive a couple of miles and it goes off and stays off until you hit high speed again.
2.0 16v 138 in the 206CC
Anyone else had this problem? I'm guessing it is just an electrical fault... But hopefully someone can shed a bit of light!
PostPosted: Tue Jan 03, 2012 5:19 am Up
One of the ABS rings on the front driveshafts will be cracked.
Common issue.
HDI90
PostPosted: Tue Jan 03, 2012 5:26 am Up
Mine did the same last night, just checked the abs ring and its cracked in 3 places
Can live with the light on for now tho its a little annoying
GTI 180
copey
PostPosted: Tue Jan 03, 2012 5:34 am Up
just dont slam on in a hurry
02 2.0 hdi d turbo
Martind
PostPosted: Tue Jan 03, 2012 5:35 am Up
Ahh right.
Ok. Thanks for the help!
crocdino
PostPosted: Wed Jan 04, 2012 11:32 am Up
That's common for the ring as everyones said.
Then 2 weeks later the sensor went on the same side!
1 week after that the other side went... ring and sensor replaced and now its fine :-S
GTI 138 facelift - Runabout
335d M Sport - Cruiser
HDI90
PostPosted: Wed Jan 04, 2012 11:36 am Up
Can you buy the rings? are they hard to fit?
GTI 180
crocdino
PostPosted: Thu Jan 05, 2012 2:08 pm Up
Can buy the rings seperate. They're sweated on. About 5-10 quid...
I'd just buy a new CV on each side. J and R CV's on ebay sell them for about 15 quid a pop.
