Online Now [1148]:
Visitors: 1147
Today: 298121
Total: 151138061
Forums › The Car › 206 Problems › Interior light and mfd stopped working
davieboy86
PostPosted: Wed Jan 04, 2012 9:02 am Up
I have my footwell lights linked up to the interior lights and for some reason they have stopped coming on when I open the door, same for the main interior light and the mfd too.
Is there a simple fuse that could have blown Maybe?
Mike_XS
PostPosted: Wed Jan 04, 2012 9:04 am Up
Yup, check the fuse box under and to the right of the steering wheel. Your manual should tell you which number fuse it will be.
davieboy86
PostPosted: Wed Jan 04, 2012 9:08 am Up
Ok sweet I should have said the interior light still works via the switch just not on the doors opening
mtempsch
PostPosted: Wed Jan 04, 2012 10:44 am Up
The switch has 2 different s12V supplies to the On vs Auto settings on the switch, one is constant 12V (still working for you) and the other is IIRC controlled via the BSI (for dimming etc).
Silvermetallic 2004 206 RC
PostPosted: Wed Jan 04, 2012 11:10 am Up
Fuse
And it's a BSI -ve not a BSI +ve Smile
davieboy86
PostPosted: Wed Jan 04, 2012 11:25 am Up
Cheers man, much appreciated I'll have a go when I finish work, I will report back soon lol.
mtempsch
PostPosted: Wed Jan 04, 2012 1:59 pm Up
Lee wrote:
Fuse
Ah, yes - it fiddles the ground for dimming, right?
But isn't there also both constant and switched +12 up there? From what I recall, the auto-mirror HOWTO seemed to indicate that...
