Online Now [1120]:
Visitors: 1119
Today: 182950
Total: 151031585
Forums › The Car › 206 Problems › 206 Outside Temp Gauge Fault
nellyhaggis
PostPosted: Wed Jan 04, 2012 1:50 pm Up
Hi All,
Has anyone had a problem with the temp gauge which I believe is on the passengers wing mirror?
Mine is showing either -1 or 0 all the time which is getting on my nerves.
Cheers.
Kevin.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
nellyhaggis
PostPosted: Thu Jan 05, 2012 6:41 pm Up
I can't believe no one has not had a similar fault on their 206!
Davies
PostPosted: Fri Jan 06, 2012 3:49 am Up
Are you sure its just not very cold all the time Smile
Poppy, My 2.0 HDI Dream Wink
twitch169
PostPosted: Fri Jan 06, 2012 3:08 pm Up
mine dont work then i got it to work and then it said -25 and i dont think lincoln gets that cold lol
peugeot 1.6 xs lowerd with black 15\" alloys custom chrome grill painted red dash and trim
nellyhaggis
PostPosted: Sun Jan 08, 2012 2:07 am Up
It's not out by much, just never moves much and it's deffinately not right.
Deckchair5
PostPosted: Sun Jan 08, 2012 2:33 am Up
Check for a bad connection at the connector between the door and the A frame. It's very common for the temperature sensor in the door mirror to go bad so if you need to change it then this may help
outside temp sensor replacement
