Latest: DanDan17
Overall: 17128
Online Now [77]:
Visitors: 75
Members: 1
Today: 15846
Total: 100414031
Forums › The Car › 206 Talk › will this bearing kit do
rick-gti
PostPosted: Fri Jan 06, 2012 3:00 am Up
found this on ebay, will i be ok to purchase it to replace the bearings on my gti 138?
www.ebay.co.uk/itm/PEU...3f103f9590
clio 197sport owner
martinius88
PostPosted: Fri Jan 06, 2012 3:20 am Up
I might be being stupid... but a link...?
206 2.0 GTi 138, Eibach: Pro-Kit, torsion bar adjusted, ULTRA angel eyes, Black Lexus rear lights, LED side indicators, Scorpion Cat back exhaust system, K&N Panel filter, theloudest.com speakers fitted all round, Sony HU.
Ibiza Cupra 1.8T 20V, JabbaSport Stage 2 Map, K03s Turbo, Forge 008 re-circ Dump Valve, N249/N111 bypass, H&R Lowering Springs, Forge FMIC. 225BHP @ 1.0 Bar. 0-60--5.6s, 1/4mile--14.2
My Old 206 GTi: www.206info.co.uk/Foru...39589.html
New Car - Ibiza Cupra: www.206info.co.uk/Foru...tml#530454
rick-gti
PostPosted: Fri Jan 06, 2012 3:56 am Up
for some reason it wasnt entered, is there now
clio 197sport owner
PostPosted: Fri Jan 06, 2012 4:59 am Up
egay seller wrote:
IF YOU CANNOT BE SURE OF CORRECT APPLICATION THEN PLEASE GIVE ME YOUR CHASSIS NUMBER!!!
If you want to do the job again in 6 months then buy it. To get the same parts from Peugeot will cost around £50. What does that tell you about the quality.
rick-gti
PostPosted: Fri Jan 06, 2012 5:07 am Up
so not really worth purchasing that then.
is that just for one side or both?
clio 197sport owner
PostPosted: Fri Jan 06, 2012 5:14 am Up
Just one side.
For things like that, it's always better going to the dealer. Might cost a bit more, but at least you know that it's made from real metal and not just been machined out of any old scrap.
rick-gti
PostPosted: Fri Jan 06, 2012 5:17 am Up
ok thanks for that
clio 197sport owner
D4NTP
PostPosted: Fri Jan 06, 2012 5:41 am Up
The dealer parts for that job are a fair bit dearer. I wouldn't buy cheap bearings for anything. They aren't a component that you can get away with a cheap version of!
If i remember correctly you need two different sized bearings to do both sides of the axle.
rick-gti
PostPosted: Fri Jan 06, 2012 5:45 am Up
i will get my mechanic to get them for me, had an advisory on mot in july about small amount of play on o/s arm.
plan to lower the rear, via removing the arms as my torsion bars wont come out. so thought as im taking them off i might as well replace the bearings.
clio 197sport owner
HDI90
PostPosted: Fri Jan 06, 2012 6:41 am Up
Ive used that kit on my xsi did the trick , just do both sides
GTI 180
gazza82
PostPosted: Fri Jan 06, 2012 7:57 am Up
Try carparts4less.co.uk ... cheaper than EuroCarParts. I've got one for an Alfa 156 on order. Someone who bought the Orbis hub kit for same car found the bearings were SKF .. and they are one of the largest manufacturers.
smithy206
PostPosted: Fri Jan 06, 2012 9:09 am Up
Im in the bearing business, and wouldnt sell them in my shop
Get branded ones, like SKF. A bit more money, but will last longer..
Adam206
FN2 CTR 210BHP
HDI90
PostPosted: Fri Jan 06, 2012 9:22 am Up
They are part of ECP
GTI 180
gazza82
PostPosted: Tue Jan 10, 2012 10:09 am Up
Looks like a permanent 25% discount on their site.
My 156 bearing arrived .. Lucas part, even though it said Orbis on the web site and order! Still it was a lot cheaper than most!
