Online Now [457]:
Visitors: 456
Today: 183539
Total: 154197926
Forums › The Car › 206 Problems › 206 SW 1.4 Engine Cutting Out
Go to page Previous  1, 2, 3, 4
finners
PostPosted: Wed Jun 08, 2011 7:23 am Up
Guess what its happened again!!!
The car had been running fine for about 30 mins but I parked it in Tesco's today and left it running for a while. It cut out when the temp gauge was at about 95C.
The fan appears to be working fine but I am completely stumped now.
Any advice guys?
206 5 DOOR ESTATE 1.4i 75 (TU3JP) Manual gearbox 5 - 54 Plate
finners
PostPosted: Thu Jun 09, 2011 4:01 am Up
The car stalled again today and the engine was not that warm so I think I can rule out it being a heat issue. It stalled and then wouldnt start again. It was turning over but just not firing which I suspect may be a fuel issue. I turned off the car for about 20 seconds and it started fine.
The wife was driving behind me and said she could smell fuel when I stalled.
Food for thought I suppose!
LeeUK
PostPosted: Fri Jan 06, 2012 4:25 pm Up
HI, did you ever get to the bottom of this?
My 2001 1.4i GLX used to cut out every now and then but would start straight away with one turn of the key no problem.
The last few weeks it has got worse and it is doing it nearly every day. Always when I'm slowing down for a junction or roundabout etc.
I've been told that it might be the fuel filter depending if it is an external one. Not sure if that is true.
2001 206 1.4i GLX
2001 Megane 1.6i Dynamique 16V
2008 207 1.4 HDI
2014 Focus 1.6 TDCI Titanium Nav
2020 Jaguar E-PACE Chequered Flag D150 AWD + 2002 Ford Focus 1.6 Ghia run-a-bout
PostPosted: Fri Jan 06, 2012 4:27 pm Up
Might be in for a long wait for a reply, thats the last time finners posted on the forum.
finners
PostPosted: Sat Jan 07, 2012 1:37 pm Up
No I never go to the bottom of it I'm afraid, sorry.
Bummers
PostPosted: Mon Feb 20, 2012 1:30 pm Up
Just having similar problems myself. Finners did you end up getting rid of the car?
Your pics have made a good guide for me to try the things you've done Very Happy
2003 206xsi 1.6 16valve
finners
PostPosted: Mon Feb 20, 2012 3:36 pm Up
Yeah I ended up getting rid of the car. I hope you get to the bottom of your problem.
Page 4 of 4
