Latest: DanDan17
Overall: 17128
Online Now [224]:
Visitors: 223
Today: 28472
Total: 100628869
Forums › The Car › 206 Problems › 2001 206 gti clock and radio display dim when lights on
m4tth3w
PostPosted: Sun Jan 08, 2012 6:58 pm Up
It's fine when lights off but when I put my lights on I cannot see display unless it is pitch black outside, if it's just getting low light outside so I turn on my side lights the display is so dim I can't read it.
Any ideas?
JonnyGTI
PostPosted: Sun Jan 08, 2012 7:56 pm Up
if im right in thinking all 206's does this
Cheers jonny
Lewis
PostPosted: Mon Jan 09, 2012 2:49 am Up
All 206s do dim these lights when the lights are on however this does seem a bit extreme! You haven't changed the bulbs behind the displays or anything have you?
Tivoli LX 1.1
Black GTI 180
White VXR Burg
gixxerkev
PostPosted: Mon Jan 09, 2012 3:09 am Up
Either a bulb(s) has gone or you need to adjust the brightness using the buttons on the instrument cluster, this procedure is in the owners handbook or somewhere on here.
An Ex '03 1.4 GLX driver, German technology all the way now.
PostPosted: Mon Jan 09, 2012 9:32 am Up
Not on the OP's car, his is non plexed so its the dimmer wheel next to headlamp leveler Wink
m4tth3w
PostPosted: Mon Jan 09, 2012 9:36 am Up
It's on full but still can't read it unless completely dark outside Sad
PostPosted: Mon Jan 09, 2012 9:41 am Up
Is the dimmer wheel working correctly on the rest of the dash / instrument cluster backlights?
m4tth3w
PostPosted: Mon Jan 09, 2012 2:58 pm Up
It only dims the instrument speedo and surround.
It doesn't dim or brighten the radio display or climate control Confused
PostPosted: Mon Jan 09, 2012 3:00 pm Up
Doesn't do it on mine either. Put it down to poor design.
