Posted: Mon Jan 09, 2012 5:10 pm |
I had a look on the halfords system at work today for my friends 206 1.6 2001 cc and it said the battery was an 013 battery but in mine i put a 012 i just wanted to check that it's defiantly an 013 not an 012 before i give it too them
| Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
TEAM: I'm a greedy jelly fiend! | |
Posted: Mon Jan 09, 2012 5:53 pm |
i use HSB013.
what's the difference anyway?
it fit into the battery box and i can close the lid no problem at all.
Posted: Tue Jan 10, 2012 4:51 am |
Halfords batteries are well over priced .. try a local parts outlet or the web!
2.0i CC is a 027 type battery ... must be a smaller one in the 1.6 version.
PS Halfords are also known to get the numbers wrong!!
Posted: Tue Jan 10, 2012 5:37 am |
I work at halfords and can get it on trade discount.
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
Posted: Tue Jan 10, 2012 7:19 am |
From what I've read the battery on a 1.6 CC is slightly taller than a normal 206
Just been to see wht's on my CC but couldn't see the number as the bracket's covering it
| Yes I own a CC and I'm neither gay or a hairdresser!! | |
Posted: Tue Jan 10, 2012 11:49 am |
I got a Bosch battery for less than £40 for mine...
Posted: Tue Jan 10, 2012 1:07 pm |
| fatboyslim wrote: |
Just been to see wht's on my CC but couldn't see the number as the bracket's covering it |
Not to worry, Thank you for look i spoke to lee earlier and if the battery i've brought is wrong i will take it back and swop it for another not the end of the world
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
Posted: Tue Jan 10, 2012 1:55 pm |
So which was it in the end??
Posted: Tue Jan 10, 2012 2:00 pm |
013 is for like a derv and way to big in physical size for the petrol.
Posted: Tue Jan 10, 2012 2:08 pm |
Does it matter?
I run the battery about three times the original size and 8 times bigger CCA, and i have no issues
So i wouldnt worry tbh
| Team Impossible Possible
Posted: Tue Jan 10, 2012 2:10 pm |
The price Mr Chafer
Posted: Tue Jan 10, 2012 2:12 pm |
| Lee wrote: |
The price Mr Chafer |
Second hand units ftw
Posted: Tue Jan 10, 2012 2:14 pm |
| Seabook wrote: |
i use HSB013.
it fit into the battery box and i can close the lid no problem at all. |
Mines the Varta D15 which is exactly the same battery as your Bosch.
Starts my TU3 easily enough
I always go for the most powerful one that will fit in the battery box with the longest warranty.
Posted: Tue Jan 10, 2012 4:27 pm |
I went for 012 and it's fine. But an 063 battery came out the car.
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
