Online Now [1874]:
Visitors: 1873
Today: 167892
Total: 152205756
Forums › The Car › 206 Problems › 2001 206 GTI Indicator And Light Stalk Problem
Lizard2010
PostPosted: Tue Jan 10, 2012 5:05 pm Up
My Indicator Light Stalk has started to play up.
Indicator stops working after a short while and the Lights come by themselves.
Car has has only done 135000 KM.
Is this normal after 10 years use?
If i need another one, is it easy to replace.
Thanks in advance Smile
Owner of a 2001 Peugeot 206 GTI 2.0 16v
PostPosted: Tue Jan 10, 2012 5:08 pm Up
2minutes and 36 seconds to change the stalk
Lizard2010
PostPosted: Tue Jan 10, 2012 5:11 pm Up
What would i do without you.
Looks like i will have to look for one.
I have to take the steering wheel off to do this?
With the Airbag do you have to have to isolate it?
PostPosted: Tue Jan 10, 2012 5:15 pm Up
Search "Stalk" by user "Lee" > look for a thread in the for sale section about "Crystal & Angel eye stalks" > guide is in there.
Airbag doesn't need to come off
Ten year old will be a 2001...non-plexed?
PostPosted: Tue Jan 10, 2012 6:35 pm Up
Its multiplexed Wink
Drivers airbag & steering wheel off job.
Time for a new com2000 unit.
Lizard2010
PostPosted: Tue Jan 10, 2012 7:53 pm Up
So what is this new com2000 unit.
Is it something different.
I have had 1 reply from a suppler, it was expensive.
Is it because it is multiplexed
Vin No is VF32CRFNF41973195.
Does that help.
marrygold75
PostPosted: Wed Jan 11, 2012 3:22 am Up
Be very carefull when you fit a new comms unit,they have a ribbon in which turns with the wheel
it plugs into the airbag you cant see it its inside the unit.
make sure your wheels a faceing streight a head.
before you put it back to gether.
then with the wheels off the ground turn the wheel fully left and fully right.
listen for the ribbon tightening up if it does just take the unit off and turn the thing in the middle the opposit way giveing you more ribbon,if you snap it your air bag light will stop on.
they cost about £180 from dealers,ebay about £70 but thats second hand.
good luck
have a nice day
Lizard2010
PostPosted: Wed Jan 11, 2012 5:22 am Up
Would anyone be able to help with a Part Number for this stalk.
PostPosted: Wed Jan 11, 2012 5:53 am Up
Peugeot / Citroen part number 6242 C2 - Control unit £189.89 is the UK price.
No idea what price it will be in your part of the world.
Lizard2010
PostPosted: Wed Jan 11, 2012 6:08 am Up
Thanks for that.
This part no is for the old style i have a later one with the radio controller.
I have found some on Ebay with these numbers.
96511186XT
96595074XT
96530926XT
Not sure which one.
Well time for sleep.
Hope to hear more tomorrow.
PostPosted: Wed Jan 11, 2012 7:14 am Up
Lizard2010 wrote:
Thanks for that.
96511186XT
96595074XT
96530926XT
Not sure which one.
The radio control stalk simply clips in, it's a separate part & you reuse your original one.
The part number I posted is the latest com2000 unit Peugeot say to fit for your car's VIN number.
Lizard2010
PostPosted: Thu Jan 12, 2012 5:27 am Up
MrBSI wrote:
Lizard2010 wrote:
Thanks for that.
96511186XT
96595074XT
96530926XT
Not sure which one.
Thanks for all your help.
Will order one tomorrow, as its getting worse.
