Latest: DanDan17
Overall: 17128
Online Now [67]:
Visitors: 66
Today: 36008
Total: 100636395
Forums › The Car › 206 Problems › Overtighten Nuts
Overtighten Nuts
PostPosted: Sat Jan 14, 2012 9:52 am Up
Basically was fitting my new brakelight today and think I may have over tightened the nut on 1 of the bolts because as I heard a slight creak noise and noticed the light sits slightly off the norm
PostPosted: Sat Jan 14, 2012 9:59 am Up
super glue it?
PostPosted: Sat Jan 14, 2012 10:03 am Up
im hoping i haven't broke the plastic which holds the bolts in, arrodite should do the trick though if I have or i'll just buy a new 1
PostPosted: Sat Jan 14, 2012 12:11 pm Up
It won't Sad
PostPosted: Sat Jan 14, 2012 12:42 pm Up
had a look and it's not broken, just a design fault with the brakelight where it doesn't sit flush but even worse, it now does not work and think the wire has got caught when tightening it Sad
PostPosted: Sat Jan 14, 2012 12:47 pm Up
Will be a simple 30second fix.
PostPosted: Sat Jan 14, 2012 1:13 pm Up
what's best to connect the wires together bearing in mind there is limited space behind the light
mtempsch
PostPosted: Sat Jan 14, 2012 2:14 pm Up
Best - I'd say solder and shrink tubing...
I went with crimp connectors (inline tube style) and that's been fine for 7 years now...
Silvermetallic 2004 206 RC
