Latest: Andyblue64
Overall: 17123
Online Now [293]:
Visitors: 292
Today: 41425
Total: 98963683
Forums › The Car › 206 Problems › New to 206 need help please
Kris1988
PostPosted: Sun Jan 15, 2012 8:36 pm Up
Hi this is my first post and seems like good forum.
We have just Been given a 52 reg 206 1.4hdi it seems
All perfect, not using oil, smoking to much ect but
The engine has a tappety, ticking noise that increases
With revs, it sounds like is coming from top of engine, the
Engine shakes a lot as well not sure if this is normal though.
Thank for any help and reading post
Kris
Rebuilding my bike, now a 206 to play with
Rob2859
PostPosted: Sun Jan 15, 2012 8:53 pm Up
Most likely the Tappets/lifters need adjusting.
Kris1988
PostPosted: Sun Jan 15, 2012 9:31 pm Up
They hydrolic tappets on the hdi so should need adjusting should they
gixxerkev
PostPosted: Mon Jan 16, 2012 6:38 am Up
Diesel engines inherently make that tapperty sound, its normal. As for the engine shaking, thats pretty normal too. I wouldn't worry about it unless it you can feel the vibration when your in the car.
An Ex '03 1.4 GLX driver, German technology all the way now.
Kris1988
PostPosted: Mon Jan 16, 2012 6:54 am Up
It's not a quiet tappety it's really loud other 206 with same engine are not like that,
Thing I'm going to end up putting in to Peugeot for £50 just to look, rip of lol
gixxerkev
PostPosted: Mon Jan 16, 2012 7:37 am Up
Oh right, if its that noisey then maybe the hydraulic tappets are being starved of oil or are sticking. Check the oil level and maybe even change whats left. I had a similar issue with hyd tappets on my Alfa a few years ago when the oil level got really low.
macj
PostPosted: Mon Jan 16, 2012 9:07 am Up
Buy a good engine flush formula like Forte....... add it to your existing oil and run up to temperature on fast idle, drain the oil and refill with new filter and good quality oil....... should sort it out
Kris1988
PostPosted: Mon Jan 16, 2012 12:30 pm Up
Didnt think engine flush was good idea but I'll give it ago, any chance it could
Be anything to do with pulley as it sounds similar to that. I'll take video
And post it tomorrow, might be more helpful
Thanks so far though
