Posted: Wed Jan 18, 2012 10:12 am |
Hi guys,
My drivers side front wheel is making a noise. And im not sure if its just wheel balancing or a wheel bearing or something else.
It doesnt do it all the time, mostly when i go on the dual carriageway and then slow down to town speeds it does it constantly after that no matter the speed.
When doing 70mph the steering wheel shakes, and at low speeds I can feel a small vibration in the accelerator pedal in time with the knocking sound.
Any ideas?
Posted: Wed Jan 18, 2012 10:46 am |
I would get the tracking looked at or jack the car up check for play by wobbling wheel (eg holding hands at 5:50 and wobble)
Posted: Wed Jan 18, 2012 1:08 pm |
could be a CV joint but you gernally hear that only when turning the wheel
Posted: Wed Jan 18, 2012 1:17 pm |
I had a similar problem. Was the Balljoint and excessive wear.
Posted: Wed Jan 18, 2012 1:39 pm |
i have the same issue, its a drive shaft issue,
