Posted: Thu Jan 19, 2012 3:59 pm |
Hi im re-building my engine on my gti 138,does anyone no the torque settings for the head bolts?
| IF IT BREAKS,IT BREAKS,ITS FRENCH! | |
Posted: Thu Jan 19, 2012 4:10 pm |
Its a small amount heading in an outwards circle then a degree
Grease the bolts before putting the new headbolts in, dont want snappy snappy now
| Team Impossible Possible
Posted: Thu Jan 19, 2012 4:12 pm |
Posted: Thu Jan 19, 2012 4:14 pm |
7/3/2/6/10
proceed bolt by bolt in the order shown
tightening torque of bolts : 5 da.Nm
tightening torque of bolts : 2 da.Nm
loosen by 1 turn(s)
tighten a further 285 degrees
This. new bolts must be used
Posted: Thu Jan 19, 2012 4:27 pm |
Seee i was right, and i didnt copy and paste
Posted: Thu Jan 19, 2012 4:29 pm |
Cheers everyone for your help
Posted: Thu Jan 19, 2012 5:32 pm |
Addaz wrote: |
Seee i was right, and i didnt copy and paste |
if you don't know you should be fired
Posted: Fri Jan 20, 2012 5:18 am |
Dont use grease on the bolt threads, use clean engine oil.
| An Ex '03 1.4 GLX driver, German technology all the way now. | |
