Posted: Sat Jan 21, 2012 6:06 am |
I have a knocking noise coming from the front end, but it only happens when I stop accelerating or start braking. I have a 2003 1.4 8v Quiksilver. Its done 116k. Cheers
| Project Low and Slow.. Going Euro for 2013. Keep your eyes peeled, big plans ahead..
See my project here. | |
Posted: Sat Jan 21, 2012 6:19 am |
Checked the wheels are done up?
Posted: Sat Jan 21, 2012 6:29 am |
I will check that in a bit, thanks
More than likely an engine mount that busted.
| This 206 IS going on a trackday despite it's every effort to stay at home in the garage! | |
Posted: Sat Jan 21, 2012 6:32 am |
ARRAN wrote: |
I have a knocking noise coming from the front end |
Bit of a vague description. Low down? High up? Left? Right? Can you feel it through the floor???
Posted: Sat Jan 21, 2012 6:40 am |
Seems to be more so in a straight line. And not really, no. Can hear it more than feel it.
Posted: Sat Jan 21, 2012 7:01 am |
straight or cornering?
it the road flat?
Posted: Sat Jan 21, 2012 7:05 am |
flat road, mainly in a straight line when deaccelerating and braking
Posted: Sat Jan 21, 2012 7:23 am |
just tightened all the wheel nuts, didnt make any difference
Posted: Sat Jan 21, 2012 9:01 am |
ive got a wobble that i can feel all the time feels like its from the front wheels and sort of effects the steering too, mines done 127k
Posted: Sat Jan 21, 2012 4:13 pm |
C.V joint, driveshafts and balljoints are all things u could check might be one of them engine mount was a good shout by D4NTP as well.
Posted: Sun Jan 22, 2012 6:02 am |
My dad thinks it sounds like something in the gearbox, like something is stuggling under engine braking. It only knocks at low speeds say 10mph, but anything over that it sounds more like a whining noise, kinda like a bearing.
Posted: Sun Jan 22, 2012 8:58 am |
ARRAN wrote: |
My dad thinks it sounds like something in the gearbox, like something is stuggling under engine braking. It only knocks at low speeds say 10mph, but anything over that it sounds more like a whining noise, kinda like a bearing. |
Sounding like another MA gearbox about to bite the dust
Posted: Sun Jan 22, 2012 9:01 am |
