Online Now [221]:
Visitors: 220
Today: 110285
Total: 155590143
Forums › The Car › 206 Talk › Front Grill removal
Front Grill removal
Forum Index › 206 Talk
thespannerman
PostPosted: Sat Jan 21, 2012 11:57 am Up
I'm trying to remove the front grill, and looking at the haynes manual it says start by removing the four push fastners accros the top (by the bonet catch) which I've done, then release the lower retaining clips - but how? The pics in the manual look like you have to pull it up, but I dont want to break this or the trim panel its attache to.
ideas/guidance please
Cheers
Al
2002 1.1 Look, China Blue, Siroccos (the go-kart)
2009 Discovery 3 TDV6 (the proper car)
PostPosted: Sat Jan 21, 2012 12:15 pm Up
The bottom of the slatted part of grill, there is 3 plastic clips each side, you can sometimes get your hand in from under the coloured part to release the clips.
Then undo the 3 torx screws, pull hard at each corner to remove the coloured trim with the badge.
Martind
PostPosted: Sat Jan 21, 2012 12:40 pm Up
When I take the front of the car apart, I take out all the bolts, then I pop of the strip that goes under the headlights, and the slatted grill that goes around the bonnet catch comes out with the strip.
I don't seperate them, but that is just me.
QuArTz
PostPosted: Sat Jan 21, 2012 12:53 pm Up
Trade Rating: +16
Be careful when you remove the trim connected to the wings with those little clips, the amount of times ive either snapped a clip or the bloody things has pooped off and fallen down behind the bumper is unreal.
Maybe im just to ham fisted.. but you will need to give it some extra encouragement to un-clip..
Martind
PostPosted: Sat Jan 21, 2012 1:14 pm Up
Haha Pooped.
Yes, those clips to break easily. Luckily I haven't broken one yet.
thespannerman
PostPosted: Sun Jan 22, 2012 4:08 am Up
I thought there was a bolt you needed to take out somewhere in the middle that you couldnt get to unless the slatted bit was out first?
Cheers
Al
PostPosted: Sun Jan 22, 2012 6:29 am Up
You can pull.the grill forwarf abit to get a screwdriver behind for the screw in the middle. i dont remove that blck plastic.grill trim either
thespannerman
PostPosted: Sun Jan 22, 2012 11:41 am Up
OK, done it - cheers fellas
Al
