Online Now [621]:
Visitors: 620
Today: 198738
Total: 155287944
Forums › The Car › 206 Problems › Clutch rattle, or something? Problem has come back....
panzer360gti
PostPosted: Tue Jan 24, 2012 1:29 pm Up
I posted some time ago that I had a high pitched rattle that can be heard even from inside the car, 206 GTi 137, V reg.
I cannot work out where this is coming from, but it happens only when moving, in all gears, appears to stay the same pitch no matter what speed I am, and is stopped by pressing the clutch in, once the clutch is up it does not re-appear straight away, but maybe 5 seconds later?
This is not a rattly engine cover like I thought before, but does anyone have a solution or idea?
Peugeot 206 GTI 137 2.0
marrygold75
PostPosted: Wed Jan 25, 2012 7:24 am Up
does it still do it if you knock it out of gear and just roll
have a nice day
Big_Rich180
PostPosted: Wed Jan 25, 2012 7:38 am Up
Your clutch release bearing has probably collapsed, if it has its new clutch time.
panzer360gti
PostPosted: Wed Jan 25, 2012 7:59 am Up
havent tried knocking it out of gear, but will, and if the clutch has gone, the car has, not spending another penny on it, got another car to use.
anybody want some pug parts?
Big_Rich180
PostPosted: Wed Jan 25, 2012 8:19 am Up
Why does no one want to fix there car when a wearing part goes?
I really dont get it, a clutch bearing can go on any car.
marrygold75
PostPosted: Wed Jan 25, 2012 11:39 am Up
the bearing usually goes louder when you press the clutch,i was thinking with the power off the drive when rolling,if it goes could it be the cv
pressing the clutch in also takes the power off.
have a nice day
panzer360gti
PostPosted: Wed Jan 25, 2012 1:33 pm Up
I just cant be doing with the expense, been given a VW for next to nothing with cam belt done and 75,000 on the clock,.
The sound does go when in neutral though, and I have got a dodgy cv boot on the drivers side, might have a look at that tomorrow just in case, as the clutch operates completely normally Sad
karimali831
PostPosted: Wed Jan 25, 2012 4:25 pm Up
Get LUK clutch, I had mine replaced today very light on and smooth feels like a new car Smile
£100 clutch £100 fitting and cheaper for older models.
206 GTI 180
panzer360gti
PostPosted: Thu Jan 26, 2012 2:52 am Up
What are Transmech clutches like?
Seen one for £66, bearing in mind Im not massively bothered about it lasting longer than 12 months.
panzer360gti
PostPosted: Sat Jan 28, 2012 11:28 am Up
Checked the CV boot and found it had a piece of earting copper wire holding it on, replaced with a proper cv strap and the clicking has gone! Result!
Must have been catching on rotation.
marrygold75
PostPosted: Sat Jan 28, 2012 3:14 pm Up
told ya
have a nice day
