Latest: Worthy967
Overall: 17143
Online Now [565]:
Visitors: 564
Today: 115121
Total: 115448230
Forums › Tuning, Modification & Legal › Project Cars › D4NTP - Track GTI
D4NTP - Track GTI
Go to page Previous  1, 2, 3 ... 6, 7, 8 ... 10, 11, 12  Next
PostPosted: Tue Jan 03, 2012 5:23 pm Up
Had the same problem with my quickshift, I ended up just tack welding it otherwise it would eventually slip Laughing
D4NTP
PostPosted: Tue Jan 03, 2012 5:35 pm Up
Thats the plan with mine. Going to get the throw how I want it then weld it up. What a s**t design! grub screws..... what were they thinking. I dread to think what there other gear is like.
PostPosted: Tue Jan 03, 2012 5:44 pm Up
D4NTP wrote:
New yellowstuff pads are now fitted. I have the new R formula pads and they actually work from cold now. Quite impressed with the life of the old ones, 6000 miles most of which was abuse.
The old pads finally died just as i had finished my last run at Blyton, one of them lost its friction material.
6000 miles is impressive
would like to see how the new pad behave
PostPosted: Tue Jan 03, 2012 5:45 pm Up
Didn't seem a very good design to me either, should have notches or something to hold it in place. I adjusted mine after it was welded and if you do it correctly aint too hard to re adjust but best to get it perfect first time
D4NTP
PostPosted: Tue Jan 03, 2012 5:58 pm Up
I think i will keep a closer eye on them this time. I cant believe how lucky i was, just pulled out of the circuit when the grinding started. Was a ball ache driving home with no brakes though.
D4NTP
PostPosted: Wed Jan 11, 2012 11:33 am Up
Bit of a minor update.....
Due to the bump i may have to cancel blyton at the end of the month but fingers crossed the physio works some magic.
As for the car, the quick shift is now fitted and working. It feels a bit strange at first as putting it in 1st, 2nd and 5th has a bit of a curling motion...but its a lot quicker.
The brakes are much improved, even over the last set of yellowstuff i had in.
I had an hour with the old girl last night doing some small jobs that were essential. all bodged tho!
1) refitted interior light.... using a tywrap.
2) put a tube on the heater outlet to direct air into the footwell as i got frost bite at blyton last time out.
3) fixed my brake light again.
Comedy pics to follow this eve after Ive put the 15's back on the front, maybe put the airbox back on and sorted out the footpad.
simon_p
PostPosted: Sun Jan 15, 2012 1:02 pm Up
you're never getting those delicately soft hands dirty are you?
just a note, i'bve read many times harnesses on c pillars aren't the greatest of ideas.
some rear end you and that area of the car crumples, all of a sudden those tight harnesses get slack.
Peugeot 206cc SPL build
2011 - 2 vibe 12" spaces, 38hz ported box, 2.5k Ground zero Nuclear mono - 141.2db @ 38hz
2012 - GZ Nuclear 12"s, 33hz box, 2 x 2.5k GZ Nuclear monos, 8" GZ comp mids, 4" GZ tweeters - 144.0db @40hz off 1500wrms
build thread -http://www.206info.co.uk/Forums/viewtopic/p=486554.html#4865540
D4NTP
PostPosted: Mon Jan 16, 2012 5:02 am Up
I don't do much in the way of dirty stuff....i've got a good mechanic for that. I stick to doing the nicer jobs...mainly in summer!
As for the harnesses I wouldn't use them on th road due to the rear ending issue and you would look a complete clown...oh and they're not comfy. However although there is a risk of having a big rear end shunt on track its fairly low compaired to the advantages the harness gives you in other situations on track.
simon_p
PostPosted: Thu Jan 26, 2012 5:38 pm Up
if thats the case surely fixed back seats would be a night and day difference. especially having proper harness routes top and bottom
D4NTP
PostPosted: Thu Jan 26, 2012 6:07 pm Up
No doubting it. Hence there will be a pair of omp trs's arriving in the spring to sort that very issue.
More than likely a customcages roll cage with harness bar also.
I just refuse to spend money on the pug when its better spent elsewhere (house, bike, others cars, trackdays etc).
If I was ever concerned by the harnesses I would just use the seat belts I left in for road use.
Having seen what the seats bolt to in peugeots I'm quite confident I'm no worse off with the harnesses.
simon_p
PostPosted: Fri Jan 27, 2012 8:48 am Up
stop being so tight. not as though you're on a pitance is it!!!
D4NTP
PostPosted: Fri Jan 27, 2012 11:54 am Up
Just hate spending money on it. If I put a load of effort and cash into it I'll stop abusing it as much. At the moment, if I write it off on a trackday I'll just go pick another shed up for 500 quid and carry on.
But youe right, effectively I'm just tight!
D4NTP
PostPosted: Fri Jan 27, 2012 1:00 pm Up
Getting a nice little freebie on Sunday at the Blyton trackday..... a free car wash by these guys
www.ultimatecarcare.co.uk/
Mattie-RS
PostPosted: Fri Jan 27, 2012 1:03 pm Up
Stop been tight!!! Razz
dont have to pay for anything to look better but atleast spend on making it faster round the track?!?!
PostPosted: Fri Jan 27, 2012 1:21 pm Up
just get a MSA log booked car next time then Razz
always got a few floating around on egay
fairly cheap these day and got basic safety device for competition
Page 7 of 12
