Posted: Mon Jan 30, 2012 12:23 pm |
Hi, guys
Basically I've got a 2000 206 gti 138bhp and the o/s/r trailing arm bearing is shot and gone way past new bearings, I've been looking on eBay and researching stuff on the net. Basically I've been told I need too make sure I buy the right year axle or my brake lines and abs sensors won't connect up.
Also would a gti 180bhp rear axle fit my car even though it carries the 2 support bars.?
Cheers Ben.
Posted: Mon Jan 30, 2012 12:27 pm |
You need a disc axle that's from a preplex car (98-01) and it will be fine. A 180 one will fit but the sensors won't be correct and the exhaust will need modifying, not worth it really.
Posted: Mon Jan 30, 2012 12:31 pm |
Ok cheers bud, so basically an axle from 98-01 206 nothing obove? Also yeh disc and abs.
Ben.
Posted: Mon Jan 30, 2012 12:32 pm |
Pm'd mate
Posted: Mon Jan 30, 2012 12:38 pm |
Not unless you want to mess around with the abs system, if it's 98-01 then it will be plug and play just make sure it's pre plexxed
Posted: Mon Jan 30, 2012 12:50 pm |
Ok, cheers mate yeh don't get multi-pled. Lol too new .
Cheers Ben.
Posted: Mon Jan 30, 2012 12:59 pm |
It's difficult to tell just by the axle, easier just asking the seller what electrical system the car was off, if they are any half decent breaker they should know
Posted: Mon Jan 30, 2012 1:01 pm |
Ok thanks bud great help. yeh right half of them just want the cash.
Posted: Mon Jan 30, 2012 2:46 pm |
sspengineering.com
Google them
Posted: Tue Jan 31, 2012 11:36 am |
Ive got a pre-plex gti 138 with movement in the trailing arm.
I can get a mint non abs drum axle for free off a damaged car.
Now if i convert it to a disc axle using parts off my gti axle, does it matter that its non abs?
ill be using the gti torsion bars and arb aswell.
cheers john
Posted: Tue Jan 31, 2012 7:20 pm |
Trade Rating: +13
I fitted a 180 axle to my 138, I just had to remove the lateral arms and swap the abs sensors and the rear hubs from the old axle to the new.
Easy peasy, about 2 hours to do the full axle change.
