Latest: heikkisj
Overall: 17126
Online Now [75]:
Visitors: 74
Today: 12406
Total: 100321790
Forums › The Car › 206 Problems › Auto button on Light Stalk
Jaffacake
PostPosted: Tue Jan 31, 2012 5:09 am Up
Hi all
Ok, first question... having gone through the owners manual several times I still cannot find out what the button on the end of the light stalk on the left hand side does? It has the word 'Auto' stencilled on there.
Is this something to do with the auto lights or am I barking up the wrong tree?
Adie Embarassed
PostPosted: Tue Jan 31, 2012 5:11 am Up
It turns the automatic headlight function ON or OFF.
If the auto headlights are working correctly leave the button alone!
Jaffacake
PostPosted: Tue Jan 31, 2012 5:32 am Up
Ahh ok. Is there any indicator light or something to tell you whether its on or off or do you just have to wait and see??
Cheers
Adie
shadow
PostPosted: Tue Jan 31, 2012 5:40 am Up
when you switch the ignition off MFD will say "automatic lighting activated"
206cc 2.0 allure
PostPosted: Tue Jan 31, 2012 5:42 am Up
Cheers
Adie
Start the engine, get out the car & hold your hand over the sensor on the windscreen.
OR
Take the car somewhere dark like an underground carpark / garage.
PostPosted: Tue Jan 31, 2012 5:43 am Up
Earlier BSI software versions dont, they will only flag it up when you use the button to change the status of the autolights.
Jaffacake
Brilliant.
Cheers Thumb Up
Adie
Ghosty
PostPosted: Tue Jan 31, 2012 5:58 am Up
you can turn it off, by putting the key in ignition (possition 1, just before you pull it out), and press the end button, you will get a ping after about 4 secs, and the mfd will tell you auto headlights deactivated (unless its the older one then i have no idea)
Team > Black HDi GTi Stage 1 tuned (140bhp, 235lbs/ft)
Team > Ex HDi D-Turbo owner
W.I.P. > www.206info.co.uk/Foru...rt=15.html
PostPosted: Tue Jan 31, 2012 5:59 am Up
Ive no idea why anyone would want to turn the autolights feature OFF, they work perfectly on the 206 Cool
Ghosty
PostPosted: Tue Jan 31, 2012 6:06 am Up
lol, its fricken annoying when you go under a bridge, and they come on, or at 3pm and its just starting to lose light they come on, if it could be set to a varying level, like sides then dipped, it would be ok. unless it does that and mine is ferked, i have never seen it auto sidelight though.
-Dave-
PostPosted: Tue Jan 31, 2012 6:10 am Up
Trade Rating: +36
Might be to stop the twenty people a week saying "ere mate you've left your lights on" and then explaining they are auto lights. I only use mine during the winter as its dark on way to work and then back home again. During the summer I tend to leave them off.
Ex 206 Owner.
PostPosted: Tue Jan 31, 2012 6:11 am Up
Sensor is defective / wants adjusting.
PostPosted: Tue Jan 31, 2012 6:12 am Up
You have older BSI software Wink
-Dave-
PostPosted: Tue Jan 31, 2012 6:15 am Up
Trade Rating: +36
Have you updated to lose the follow me home feature?
Ex 206 Owner.
PostPosted: Tue Jan 31, 2012 6:16 am Up
Follow me home function now needs you to flash the headlights after key is turned off to get the dipped beam to stay on for the 30 seconds.
