Latest: sparrowdclxvi
Overall: 17139
Online Now [252]:
Visitors: 251
Today: 23636
Total: 113144863
Forums › The Car › 206 Problems › Struggling to start
Struggling to start
Go to page 1, 2, 3  Next
TY-HDI
PostPosted: Wed Feb 01, 2012 3:07 pm Up
Hi guys, Just got a new 206hdi and it's struggling to start. Bought it saturday and it started fine all day, then parked up saturday night until monday morning as I was sorting insurance etc...and since then it's struggling.
I let the glow plugs warm etc, go to fire it up and it turns a few times then spurts into life. Once running it starts fine again, but then if stood for a few hours it struggles again. I checked the battery today and its giving out 12v stood and 14odd running so that seems fine, Is it likely to be the glow plugs? Iv never had glow plugs go so not sure what the symptoms are.
206Hdi Mapped. De-cat next
PostPosted: Wed Feb 01, 2012 3:15 pm Up
any lights on the dash,or mesg. on your MFD?
TY-HDI
PostPosted: Wed Feb 01, 2012 3:18 pm Up
Whats MFD? Um, light on the dash whilst running? If so no, or when i turn key before starting all the normal lights come up.
Martind
PostPosted: Wed Feb 01, 2012 3:23 pm Up
What engine is it?
I had a similar problem with a 307 2.0 HDI 110. Same Symptoms
Changed the Glow Plug Relay, Glow Plugs and had it plugged into 2 different diagnostics (Showed No Faults).
Had the injectors Re-Furbed and now it all seems Ok.
TY-HDI
PostPosted: Wed Feb 01, 2012 3:31 pm Up
2.0 Hdi. Seems strange. So even after you changed your plugs it still did the same?
Martind
PostPosted: Wed Feb 01, 2012 3:36 pm Up
Yep changed them and still a pig to start
PostPosted: Wed Feb 01, 2012 3:39 pm Up
Battery
the pre-heating time in this weather is still next to nothing
12.0v reading from battery is really low, normally you should see at least 12.5-12.6v;
i would be surprise if you can start the engine
TY-HDI
Oh. just dont understand why it was fine saturday and when its been running, but not when its been stood.
PostPosted: Wed Feb 01, 2012 3:40 pm Up
Lee wrote:
Battery
d**n Razz
lmilligan
Definitely the battery, had to replace mine today.
TY-HDI
PostPosted: Wed Feb 01, 2012 3:48 pm Up
Well yeah it was 12.4V. Should I give the battery a full charge tonight to see if that helps?
PostPosted: Wed Feb 01, 2012 3:49 pm Up
12.4v sounds fine to me :s
did you smell burning engine oil from the exhuast?
it is common that engine oil drip into the cylinder due to worn valve/ piston ring. quite common in the HDi block which cause difficult engine start first thing in the morning
TY-HDI
PostPosted: Wed Feb 01, 2012 3:54 pm Up
Cant say i noticed anything no. Seems to give a puff of smoke when it does fire though
TY-HDI
PostPosted: Wed Feb 01, 2012 4:02 pm Up
Should I try charging the battery? Changing glow plugs?
Page 1 of 3
