Latest: sparrowdclxvi
Overall: 17139
Online Now [138]:
Visitors: 137
Today: 2389
Total: 113492236
Forums › The Car › 206 Problems › GTi misfire.
GTi misfire.
G2iFF
PostPosted: Thu Feb 02, 2012 8:51 am Up
Hi guys, could probably have searched this, but havent got time, need to get my car in order, hopefully so i can drive to work tonight!
Basically last night i was driving from leics to leeds, ran perfectly fine, then on the way back, ran perfectly fine, then 1 mile away from my house as i pulled off the motorway, out of nowhere, in 2nd gear, it lost a hell of a lot of power, misfired like hell, engine management light started flashing. it still drove, but with considerably less power than usual and it ran dog rough... when i got back i turned it off, left it a minute, then started her up again, took it round the block, it ran better, but the management light was still flashing, and there was still a slight misfire..
a couple of weeks ago i cleaned the ICV, and changed the paper filter... the last week replaced the centre section of the exhaust and the back box, with a new standard one...
Its an 02 plate, gti 138
Any ideas?
Cheers
2002 206 GTi
gaffy
PostPosted: Thu Feb 02, 2012 9:01 am Up
Sounds as if your coil pack is on it's way out, I'm sure someone will correct me if I'm wrong good luck
chin up lad
PostPosted: Thu Feb 02, 2012 12:22 pm Up
Such behaviour is normally caused by the coilpack or hydraulic lifters. I'd go for the coil pack and some new spark plugs first.
