Posted: Fri Feb 03, 2012 3:56 am |
Opened my drivers door this morning and the rear wiper started wiping for about 10 seconds then stopped in the wrong place.I switched the ignition on and it reset itself.Went to have a look at it and every time i touched it it would move a few times and then stop even with the ignition off?
Surely this cant be normal?
Posted: Fri Feb 03, 2012 4:02 am |
Transformers?
Or possibly low battery charge.
Posted: Fri Feb 03, 2012 4:05 am |
Battery is a new one.
Posted: Fri Feb 03, 2012 4:11 am |
When you changed it did you disconnect it correctly & do a BSI reset?
Posted: Fri Feb 03, 2012 4:37 am |
Yep did all that. Maybe it just doesnt like the cold.
Posted: Fri Feb 03, 2012 4:48 am |
Trade Rating: +32
| CD-B3 wrote: |
| Transformers? |
Don't think you can blame the Autobots mate.
Posted: Fri Feb 03, 2012 9:43 am |
mine has done this before and so has my mates 306. maybe its just a peugeot thing lol
Posted: Fri Feb 03, 2012 10:18 am |
Hasnt done it since this morning.So must be the cold.
Its really going to play up tomorrow when it snows.
Posted: Sun Feb 05, 2012 3:54 am |
Mine does this whenever its cold out. It usually gets better once the car has warmed up.
Posted: Sun Feb 05, 2012 7:28 am |
Did it again this morning but stops doing it once it warms up. At least mine Isnt the only one.
Posted: Sun Feb 05, 2012 3:12 pm |
Could be frozen and the motor continuously trying until it unsticks itself. Don't use it and when you put the car in reverse, try and make sure the front wipers ain't on.
