Latest: dreyfalon
Overall: 17121
Online Now [562]:
Visitors: 561
Today: 67220
Total: 97367221
Forums › The Car › 206 Problems › burning smell
burning smell
scotty79
PostPosted: Fri Feb 03, 2012 9:58 am Up
this mornin when i got to work there was a funny burning smell coming from the exhaust and my car at the moment sounds like an impreza, could this be the cat needing cleaned or replaced or could it be something else?
LeeMaddern
PostPosted: Fri Feb 03, 2012 10:28 am Up
Which engine ?
More photos on FaceBook - www.facebook.com/lmaddern1
scotty79
PostPosted: Fri Feb 03, 2012 10:45 am Up
2.0 gti
Big_Rich180
PostPosted: Fri Feb 03, 2012 10:52 am Up
Misfiring, cold be the coil pack.
scotty79
PostPosted: Fri Feb 03, 2012 11:03 am Up
it's not misfiring, just has the smell and the exhaust kind of splutters if that makes sense but there is fumes coming out of it so it's not blocked
Big_Rich180
PostPosted: Fri Feb 03, 2012 11:06 am Up
But you say the car sounds like an impreza, this is normally a sign of a misfire.
Does it actually sound like an impreza as in it burbles like a boxer engine would?
scotty79
PostPosted: Fri Feb 03, 2012 11:09 am Up
to me it just sounds like the exhaust that's on an impreza, I know it's not much help lol but to me that's just what it sounds like
PostPosted: Fri Feb 03, 2012 2:03 pm Up
Check the oil
scotty79
PostPosted: Sat Feb 04, 2012 5:32 am Up
checked the oil, it's fine, takin it to the garage on Monday till they check the cat, the smell seems to have gone just the noise now
PostPosted: Mon Feb 06, 2012 2:31 pm Up
so what did the garage said?did you fixed it?
crocdino
PostPosted: Mon Feb 06, 2012 2:48 pm Up
You checked for a plastic bag stuck to the exhaust? That could be your burning smell, can't say what would cause the noise.
GTI 138 facelift - Runabout
335d M Sport - Cruiser
scotty79
PostPosted: Tue Feb 07, 2012 3:02 am Up
cat looks fine, checked plugs and they look fine also, so going to replace coil pack and see if that helps, noticed that they are ngk plugs so gonna ask them to get me bosch super 4's? see if that makes a difference
also should i be driving around in this or should it be parked up till the coil pack comes through?
scotty79
PostPosted: Wed Feb 08, 2012 11:58 am Up
meant to add, when he was checking the plugs 2 of them had oil on them but he couldn't see any oil where the plugs were taken out of, I'm hopin this isn't leading to anythin more serious or the cars goin for scrap
PostPosted: Wed Feb 08, 2012 12:27 pm Up
Scrap Shocked
Being a GTI there will be plenty of youngsters on here after the parts so break it first Wink
scotty79
PostPosted: Wed Feb 08, 2012 12:49 pm Up
I'm guessin the oil in the plugs isn't a good sign then, I would probably be able to take some parts off it but not many as i dont really have the time or knowledge to totally strip a car down
