Online Now [555]:
Visitors: 554
Today: 156450
Total: 154173140
Forums › The Car › 206 Problems › Rain sensitive wipers
Go to page Previous  1, 2, 3
PostPosted: Sun Feb 05, 2012 12:20 pm Up
You will have Auto wipers I pretty sure of that.
Auto wipers do play up and it normally a sign that the sensor is on its way out. My auto wipers work fine when I use them. Inter will stop when you stop and will speed up when you speed up.
Ahoward87
PostPosted: Sun Feb 05, 2012 12:22 pm Up
macca1411 wrote:
Are you still bitter from yesterdays result? Wink
If life passes you by...... Shift down!
1/4 mile: full interior and sound system.
Reaction: .6067 60 Ft: 2.3343 330Ft: 6.6654 1/8 ET: 10.2421 1/8 MPH: 68.70 1000' ET: 13.2334 1/4 ET: 15.9189 1/4 MPH: 86.35
Ahoward87
PostPosted: Sun Feb 05, 2012 12:25 pm Up
Ah I see,
Sorry I was just confused before as I thought you was being sarcastic. My stork still only has the four settings off, auto, slow and fast so my auto sensor must be duff.
PostPosted: Sun Feb 05, 2012 12:29 pm Up
Yeah if you have got Auto you wont have inter setting.
My wipers are very rarely used now since I nano'd my screen.
PostPosted: Sun Feb 05, 2012 12:32 pm Up
Never bitter. It has helped our campaign to show how tactically inept Steve Kean is.
Ahoward87
PostPosted: Sun Feb 05, 2012 12:34 pm Up
Where did you get the windscreen sealed and does it make a worthwhile difference?
Ahoward87
PostPosted: Sun Feb 05, 2012 12:37 pm Up
Only joking dude , I'm just buzzing as our new signing bagged a winner for us today. It's not just kean that is inept, the board are also in need of being washed out, anyway, bit off topic lol
PostPosted: Sun Feb 05, 2012 12:38 pm Up
Ahoward87 wrote:
After saying that, I'm thinking your right, I probably haven't got auto wipers because mine is off, auto, slow speed and fast speed. If I haven't got auto wipers why the he'll is my intermitant wipers having a mid of it's own and only wiping at irregular times
Ahoward87
PostPosted: Sun Feb 05, 2012 12:44 pm Up
I meant to write inter.. Smile
PostPosted: Sun Feb 05, 2012 1:41 pm Up
Did it myself and yes makes a big difference
Martind
PostPosted: Sun Feb 05, 2012 3:44 pm Up
Ahoward87 wrote:
Yes they are auto wipers. Its bloody annoying when it's only spitting as I have to manually do it by pushing the stalk down. My wipers can make noise if there is not enough water on the windscreen. Sad
Could it possibly be that you need new wiper blades?
I'm not 100% sure, but if the wipers aren't clearing the sensor sufficently it will wipe again because it is sensing that there is still water on the screen.
From personal experiance, if they are making noise you may be due a new pair anyway.
Might as well give it a try, cheaper place to start than a new sensor.
I would recommend Aero wipers. ASDA sell them now (Well, my local Asda does) or eBay.
Ahoward87
PostPosted: Fri Feb 17, 2012 2:19 am Up
Thanks Martin, i went and got some Bosch aero wipers and they clear the windscreen much better and the auto wipers work a treat now as the old wipers were not clearing the rain off the sensor as they should.
Page 3 of 3
