Posted: Tue Jan 31, 2012 2:56 pm |
Hi again all
My hdi engine vibrates at idle with the metal pipe (aircon ?) at the front top shaking about, is this normal?
Also the car seems to have a rattle/noise at low revs that disappears as the revs build usually about 2300 to 3000 rpm and goes silent (well as much as a diesel can). It doesn't seem to be coming from the pulley are though. Again is this normal or does anybody have any ideas I can check.
In the meantime it's axle bearing change time this weekend.
Posted: Sat Feb 04, 2012 12:50 pm |
crank pulley common fault
Posted: Sun Feb 05, 2012 1:20 pm |
Thanks. Doesn't seem to be the pulley and after searching all threads it may be an injector. I'm running bg 244k through it at the moment.
For the future as I may change the pulley anyway, is it the timing crank pulley ( that the timing belt runs off) or is it the accessory pulley.
Posted: Sun Feb 05, 2012 3:25 pm |
the big pulley at the bottom of the aux belt.
on my 1.4hdi i had a rumble at tickover and it was the alternator pulley (belt tensioner was bouncing).
| Former owner of a 1.4 HDi for six years | |
Posted: Sun Feb 05, 2012 4:18 pm |
I will have another check of pulleys this week. Just sprayed a bit of grease on the pulleys and it now seems to be just engine noise ( no rattle) I won't really know till tomm though.
