Online Now [478]:
Visitors: 477
Today: 21020
Total: 157043126
Forums › The Car › 206 Talk › Crystal Headlights which ones?
Forum Index › 206 Talk
ruby_the_206
PostPosted: Fri Feb 10, 2012 4:00 am Up
Hi sorry this probably been said many times but the search on here takes me 3 hours to find the right thread im after
Anyway i have a 52 plate lx and i want to get crystal headlghts been looking on ebay and it says something about lowline and highline lights which ones do i need?
Also will they simply be a straight swap as i dont want to be messing with any wires
Thanks Smile
Ruby
jimjam19927
PostPosted: Fri Feb 10, 2012 4:36 am Up
If you have a lx the chances are you have h4 connectors. You need to make or buy h4-h7 connector adapters if you want crystals.
Not sure about the highline and lowline thing just make sure you get RHD ones that. I recommend Valeo as a branding for crystals as they are the OEM ones peugeot use.
Member: 685
I Over Use Smilies Razz
PostPosted: Fri Feb 10, 2012 4:43 am Up
For some reason people on ebay call phase 1 lowline and phase 2 highline Confused Not sure what it means either but highline will be crystal lights.
On Georgie's 52 plate he had the H7 connectors fitted but taped up. Its worth a look because they may be there already. Smile
Ghosty
PostPosted: Fri Feb 10, 2012 5:40 am Up
lowline = base models (frosted)
hi-line = top models (crystals)
well thats how most people view it, as said make sure you get converters if yours dont have the h7 connector, as for the branding valeo is oem, but costs more than say depo Very Happy :D
Team > Black HDi GTi Stage 1 tuned (140bhp, 235lbs/ft)
Team > Ex HDi D-Turbo owner
W.I.P. > www.206info.co.uk/Foru...rt=15.html
Dillon
PostPosted: Fri Feb 10, 2012 5:45 am Up
Staff - Dillon
I had both the H4 and H7 connectors on my 52 as well but not all had them.
TimHDi
PostPosted: Fri Feb 10, 2012 7:07 am Up
Where can you get the adaptors from?
PostPosted: Fri Feb 10, 2012 7:14 am Up
You can make them for a couple of quid Smile Maplins sell the bits.
TimHDi
PostPosted: Fri Feb 10, 2012 7:18 am Up
Anywhere they can be bought ready done?
Matt
PostPosted: Fri Feb 10, 2012 7:46 am Up
Trade Rating: +32
I have H4 & H7 on my 02.
TimHDi
PostPosted: Fri Feb 10, 2012 7:47 am Up
Nice. I don't on my 01 unfortunately.
ruby_the_206
PostPosted: Fri Feb 10, 2012 9:08 am Up
ok thanks il have a look then but what exactly am i looking for to see if they are H4 or H7? sorry for being thick Confused
Ruby
TimHDi
PostPosted: Fri Feb 10, 2012 9:12 am Up
Just found these, may be of some help:
www.body-kit.co.uk/pro...4s-pe07l26
phillspug
PostPosted: Fri Feb 10, 2012 9:14 am Up
Hmm not sure if my lights will be a straight swap with yours then dude as I've got h4 & h7 on mine Confused
Jack69795
PostPosted: Mon Jan 19, 2015 12:14 pm Up
Im gonna buy those adapters from body-kit , if i use these i dont need any relay do i ? Also do i need to change my indicator & headlight stalk (i have the 2001 lx)
mtempsch
PostPosted: Mon Jan 19, 2015 2:10 pm Up
If you mean those n the page TimHDi linked - from the page:
"From the 2003 facelift the standard Peugeot 206 changed from H4 to H7 headlight bulbs within the same headlight chassis.
To use Ultra Headlights: PE07L24, PE07L24S & PE07L26S in facelift models you should use: APE07 HARNESS ADAPTER KIT to adapt the H4 headlight unit to the post facelift H7 wiring loom.
These Adapter Kits are designed for use with Ultra Brand headlights, they CANNOT be used to upgrade pre-facelift models from H4 to H7 bulbs."
Sounds to me like they're the other way round, adapting an H7 harness to their brand of lights originally made for H4 harness cars.
Silvermetallic 2004 206 RC
