Online Now [373]:
Visitors: 372
Today: 115544
Total: 156222134
Forums › The Car › 206 Talk › PPT Type?
PPT Type?
Forum Index › 206 Talk
LKHtyke
PostPosted: Fri Feb 10, 2012 2:36 pm Up
Hi all,i'm thinking of getting a 206 hdi (2.0) due to my daily commute to work more than doubling at the end of the month.
I am thinking of a 2003(53) or 2004 model d turbo or xsi spec car and was wondering what type of PPT is factory spec in these models,and what features they have? temp/mpg etc.
Thanks,
BARNSLEY FC
PostPosted: Fri Feb 10, 2012 2:39 pm Up
Dont worry about what screen the car comes fitted with.
Trip computer / 3 line display is an easy / cheap enough retrofit on a multiplexed 206 if it doesnt already have it fitted Wink
PostPosted: Fri Feb 10, 2012 2:50 pm Up
I'm in the process of buying the parts need to retrofit a trip computer and temp sesor for my car,but can't find a COM2000 with the trip computer button,so do you have one MrBSI?? Wink
PostPosted: Fri Feb 10, 2012 2:51 pm Up
Is your com2000 not the type where you can just replace the end cap?
Reminds me, i must fix my com fault Laughing
PostPosted: Fri Feb 10, 2012 2:55 pm Up
I have the cap looks like a button on the wiper stalk side,but not sure if I can take it off,can I?
PostPosted: Fri Feb 10, 2012 2:57 pm Up
Some com units you can just remove the end part of the stalk with the cap inside & replace it with 1 with the button fitted.
The other type of com you cant, its replace the complete unit.
PostPosted: Fri Feb 10, 2012 2:58 pm Up
mmmm..and how can I be sure what model is mine?how it can be removed,twist it,or pull it out!
PostPosted: Fri Feb 10, 2012 3:00 pm Up
If its the type you can remove the end then there clipped on, clips also break very easily Laughing
Stick a picture up of the wiper stalk.
PostPosted: Fri Feb 10, 2012 3:03 pm Up
Well do tomorrow morning,because it's 11:00 PM now here,and it's freezing cold outside,other wise I would take a pic. now and post it ;),thank you MrBSI for your help Very Happy
PaddyC
PostPosted: Fri Feb 10, 2012 3:47 pm Up
Mine had the button on the indicator stalk and no button just a cap on the wiper stalk. A thin narrow blade helped pop both out and then swopped them over. Took all of 60 seconds. Then the button now on the wiper stalk should let you scroll through the display options if the BSI has the function installed. Fortunately, mine did.
Peugeot 206 1.4HDI Style
