Posted: Sat Feb 11, 2012 12:15 pm |
Oh no one has told me that ! Is that one model? No it's superchipped by r tech it's about 190 ish
Posted: Sat Feb 11, 2012 12:26 pm |
Im sure the golfs have a voltage regulator too, there normally on the alternator. If you are a member of uk-mkiv im sure a search for voltage regulator, might throw up help. Did it just throw lights on the dash, or are there any symptoms too? Have you vag com'd it?
Posted: Sat Feb 11, 2012 12:29 pm |
It's just the lights, nah I havnt yet no one is close to me to do it
Posted: Sat Feb 11, 2012 12:33 pm |
If you buy the cable £10 off ebay ill send you the software! Have you measured what the battery voltage when the car is turned off, and when the engine is running?
Posted: Sat Feb 11, 2012 12:43 pm |
Yeah it's 12.5 off 13.9 idling. Aww sweet cheers mate I can just put it on my laptop can't I?
Posted: Sat Feb 11, 2012 12:55 pm |
Sounds like everything is alright there then, what are the lights doing? just flickering? if you pm me your email ill send it across to you.
Posted: Sat Feb 11, 2012 1:25 pm |
It just the abs light comes on and when I check the code it's battery power supply yeah will do mate
Posted: Sat Feb 11, 2012 2:15 pm |
I have pmd you
Posted: Sun Feb 12, 2012 9:17 am |
Posted: Sun Feb 12, 2012 9:26 am |
Posted: Sun Feb 12, 2012 9:35 am |
im gonna get a new wing soon as its been keyed as well
Posted: Wed Feb 15, 2012 5:37 pm |
the GTI vinyl def needs to go would look alot fresher without.
| F**k Scene YAWN
Project GreenMachine: 206info.co.uk/Forums/v...rt=75.html | |
Posted: Mon Feb 20, 2012 11:28 am |
had a bit of a clean after my new tyre was fitted .......... 150 quid for a goodyear ! f*** tyres are expensive
Posted: Mon Feb 27, 2012 4:05 pm |
looks good did you get your problems sorted?
Posted: Mon Feb 27, 2012 4:07 pm |
Yeah bad earth on the gear box I just didn't see it only cost 25 and they checked my hole car
