Posted: Sat Feb 11, 2012 2:36 pm |
i have noticed a few times that when i first start the car on a morning the doors will lock and some times the air bag fault comes on. if i run the car for a little bit then turn off and restart the airbags are ok again. any ideas?
Posted: Sat Feb 11, 2012 2:37 pm |
You need a new battery - end of thread.
Posted: Sat Feb 11, 2012 2:38 pm |
| MrBSI wrote: |
| You need a new battery - end of thread. |
No, what he needs is a new car.
Posted: Sat Feb 11, 2012 2:39 pm |
| MrBSI wrote: |
how do you know that?
Posted: Sat Feb 11, 2012 2:40 pm |
| vauxfan wrote: |
| MrBSI wrote: |
how do you know that? |
I just do
Posted: Sat Feb 11, 2012 2:44 pm |
i had he battery checked at a local and said the cca was 300, i tested the battery and it was 12.6volts and charging at 14.4v, but that was after driving it! i havn't checked it after leaving over night though!
peugeot say 300cca is correct for this car, but the local said he had 2? one at 300cca and a heavy duty 1 at 450cca. i thought it was low as my bm is 650cca. but he assured me they are 300cca.
Trade Rating: +59
| LeeThr wrote: |
| MrBSI wrote: |
No, what he needs is a new car. |
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Sat Feb 11, 2012 2:46 pm |
| G. wrote: |
| LeeThr wrote: |
| MrBSI wrote: |
I knew it wouldnt be long before the FAPmaster saw this thread
Posted: Sat Feb 11, 2012 2:50 pm |
so far guys i love this car! i use it more than the bm,, bet you didn't think you would here that! i never thought i would say it! as for the potesial faults, well i have money aside just in case so thats not a problem. and i have done clutches before on 206s, aswell as many wishbones, exhausts and drive shafts. so if i had to do some unexpected things myself it won't be a problem..
as for the new battery thing. all the cars i have had either didn't turn over of electrics flashed on with headlights(bm) i take it this is from experiance?
Posted: Sat Feb 11, 2012 2:51 pm |
I've already told you how to fix it, what you do with the information i've given is up to you.
Posted: Sat Feb 11, 2012 2:54 pm |
| MrBSI wrote: |
| I've already told you how to fix it, what you do with the information i've given is up to you. | i am great full for the advice, i am just curious how you know? its all about passing on the knowledge. its intresting to me how you know these things.
Posted: Sat Feb 11, 2012 3:06 pm |
it's quite common in mux 206. when battery is low random warning light will come on itself
Posted: Sat Feb 11, 2012 3:13 pm |
| Seabook wrote: |
| it's quite common in mux 206. when battery is low random warning light will come on itself |
Im waiting for the " whats a mux 206? " question
I managed to get the ESP warning light on my car, not bad seeing as it doesnt even have ESP fitted
Posted: Sat Feb 11, 2012 3:19 pm |
| MrBSI wrote: |
| Seabook wrote: |
I managed to get the ESP warning light on my car, not bad seeing as it doesnt even have ESP fitted  |
Well done
You truly are the master
Posted: Sat Feb 11, 2012 3:34 pm |
| MrBSI wrote: |
| Seabook wrote: |
Same with me with the ABS and seat belt warning light
