Latest: dreyfalon
Overall: 17121
Online Now [403]:
Visitors: 402
Today: 47583
Total: 97451330
Forums › The Car › 206 Problems › Rear Beam
Rear Beam
nellyhaggis
PostPosted: Sun Feb 12, 2012 4:26 am Up
Has anyone fitted a GTI 180 rear beam to a normal 206?
Is it a straight swop?
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PostPosted: Sun Feb 12, 2012 4:38 am Up
Depending on the age of your car the ABS sensors could be different and the lateral links will hit your exhaust.
nellyhaggis
PostPosted: Sun Feb 12, 2012 5:23 am Up
its a 206 gti hdi.
I wanted the 180 beam as it has the supports/tie rods.
PostPosted: Sun Feb 12, 2012 5:30 am Up
well you won't have the mounting point to fit them and you will need custom exhuast and remove the spare tyre+cage
