Forums › The Car › 206 Problems › Rear Beam |
Posted: Sun Feb 12, 2012 4:26 am |
Has anyone fitted a GTI 180 rear beam to a normal 206?
Is it a straight swop?
| - Sinature removed due to size.
Please feel free to upload one of the correct dimensions. | |
Posted: Sun Feb 12, 2012 4:38 am |
Depending on the age of your car the ABS sensors could be different and the lateral links will hit your exhaust.
Posted: Sun Feb 12, 2012 5:23 am |
its a 206 gti hdi.
I wanted the 180 beam as it has the supports/tie rods.
Posted: Sun Feb 12, 2012 5:30 am |
well you won't have the mounting point to fit them and you will need custom exhuast and remove the spare tyre+cage
