Latest: dreyfalon
Overall: 17121
Online Now [542]:
Visitors: 541
Today: 96790
Total: 97396786
Forums › The Car › 206 Problems › Removing handbrake cables from rear caliper.
PostPosted: Sun Feb 12, 2012 1:55 pm Up
Does anybody know how the handbrake cables are removed from the rear brake calipers?
I've disconnected mine from the lever, pulled them through from inside the car but they are stuck in the caliper. Where the cable slots in the caliper there seems to be a little sleeve on the outer cable. Has anybody managed to remove it? Otherwise how do the cables come out? I don't want to damage them as they are getting refitted.
PostPosted: Sun Feb 12, 2012 2:28 pm Up
They just pull out.
PostPosted: Sun Feb 12, 2012 2:34 pm Up
Mine don't. Pull them so hard they stretch...
PostPosted: Sun Feb 12, 2012 2:37 pm Up
Tried putting a small screw driver in to prise it out? They have just pulled out on the ones I've done before.
samreecestrange
PostPosted: Sun Feb 12, 2012 2:56 pm Up
Mine were really difficuly to get out too!
I soaked them in maintenance spray and hour later came out easy
Signature removed due to size
meady
PostPosted: Sun Feb 12, 2012 4:33 pm Up
Trade Rating: +45
they do just pull but they can be really difficult to do
TEAM - I HATE FACEBOOK Smile
PostPosted: Sun Feb 12, 2012 4:59 pm Up
Right I've ordered some Plus Gas to help shift them. I don't need to remove them but I'd like the out of the way when the calipers and axle get removed.
It will also help shift the torsion bars which are a little tight despite being covered in copper grease but they've been in there over 7 years.
PostPosted: Sun Feb 12, 2012 5:10 pm Up
When i had axle exchanged, they removed the brake cables and abs lines, which made the plastic fitting which are on the axle and trailing arms useless. I think there fitted like cable ties, so once there off there useless, can you get replacments of these parts? Mine are just cable tied on, but it does the job, I know you'll like your car to be OEM!
PostPosted: Mon Feb 13, 2012 2:50 am Up
Dealer sells the clips on the arms yes. I am thinking of replacing mine. I am definately replacing the metal pipe and cable guides and brackets too.
