Posted: Sun Feb 12, 2012 3:16 pm |
Just wondering what the differences are between the right and left strut, they look the same to me. Even the pistons look the same length.
Also what would happen or what problems would be caused by the right strut been put on the left and vice versa?
Posted: Sun Feb 12, 2012 3:34 pm |
Mine aren't sided
Posted: Sun Feb 12, 2012 3:47 pm |
Oh thought i read on here that they were.
Posted: Sun Feb 12, 2012 3:50 pm |
Mine weren't either.
Posted: Sun Feb 12, 2012 3:54 pm |
I thought they were sided, because of were the droplink connections are?
Posted: Sun Feb 12, 2012 3:57 pm |
The brackets make them sided.
| 206 1400 8v HDi, Battle Bus - More Radical than Peugeot
In theory, there is no difference between theory and practice. In practice, there is. | |
Posted: Sun Feb 12, 2012 4:00 pm |
Squeaker wrote: |
Oh thought i read on here that they were. |
i use coilies so that might not be helpful
is the drop link mounting hole at the same place?
Posted: Sun Feb 12, 2012 4:07 pm |
Seabook wrote: |
is the drop link mounting hole at the same place? |
It shouldnt make a difference that your using coilovers, you still need to connect coilovers, but thinking about it, they must be the same either way there fitted.
Posted: Sun Feb 12, 2012 4:43 pm |
So if its just the droplink mounitng spaces, what problems would be caused by putting wrong one on wrong side?
Posted: Sun Feb 12, 2012 4:47 pm |
None as far as i can think. As long as they fit the hub, and everything conects ok.
Posted: Sun Feb 12, 2012 5:11 pm |
Steve206 wrote: |
Seabook wrote: |
It shouldnt make a difference that your using coilovers, you still need to connect coilovers, but thinking about it, they must be the same either way there fitted. |
the bracket for the drop link can rotate on my coilies, plus i don't run front ARB
Posted: Mon Feb 13, 2012 4:08 am |
my h&r cups are sided its the mount for the arb drop links that make them sided they are slightly offset
