Posted: Sun Feb 12, 2012 7:42 pm |
Some times when i lock my car and then unlock it, the boot lock motor won't move which means each time i have to pull back the rear seats and push the catch along manually. This usually only happens when i haven't used the boot in 2 - 3 days so i guess it might need some greasing up??? Is this a common problem???
Posted: Mon Feb 13, 2012 12:36 am |
this happened to me before, couldn't get the boot open at all though, had to get the actuator(?) replaced
Posted: Mon Feb 13, 2012 3:29 am |
Does it make an unusual sound the times it won't open? Might be the actuator on its way out.
Posted: Mon Feb 13, 2012 4:54 am |
No, no strange noises, it usually happens when i don't use my boot in a while and can be really f*****g annoying sometimes lol. I have to keep sliding catch across manually, opposite the keyhole from the inside there a little hole with a flap so just stick finger in there and slide it across and took me like 10 mins to figure it out :/ Is it something i could go to a scrap yard and wrip out of another 206????
