Online Now [1415]:
Visitors: 1414
Today: 170730
Total: 155261395
Forums › The Car › 206 Talk › Fitting momo steering wheel??
Forum Index › 206 Talk
Ahoward87
PostPosted: Tue Feb 07, 2012 2:58 pm Up
I have just purchased this below
I have fitted aftermarket wheels before but without linking the horn up. So has anyone fitted one that could advise me on how to fit it properly with the horn working etc.. ?
Also is there certain boss's that I should stay away from like, without self the cancel bit or something like that?
If life passes you by...... Shift down!
1/4 mile: full interior and sound system.
Reaction: .6067 60 Ft: 2.3343 330Ft: 6.6654 1/8 ET: 10.2421 1/8 MPH: 68.70 1000' ET: 13.2334 1/4 ET: 15.9189 1/4 MPH: 86.35
PostPosted: Tue Feb 07, 2012 3:07 pm Up
Fitting / having that steering wheel will be an MOT failure on a 206 from April.
Pointless mod on a road car.
Just sell it on & let some chav find out the hard way Wink
usher
PostPosted: Sat Feb 11, 2012 1:54 pm Up
why will it be mot fail new rules etc
and its easy to do just connect the wires to the new horn cant go wrong really
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Sat Feb 11, 2012 2:23 pm Up
Correct.
All UK spec 206 had a drivers airbag factory fitted so removing it will be an automatic mot fail Thumb Up
Ahoward87
PostPosted: Mon Feb 13, 2012 7:58 am Up
I am not permanently keeping the steering wheel on and would like to take it to a track once or twice a year so I could easily swap the wheel over as it take about 5 minutes to swap over.
I have used a 2amp fuse that has been soldered to two wires and connected the air bag connector and completes the circuit so the warning light works as it should, my only problem is how to wire the horn up correctly and I have no access to a multimeter until I return to work on Wednesday and to be honest I'm not all to clued up on the electrical Side of things.
My problem is that in the picture below you will see the original connector and two wires with spade connectors that I will be connecting back in. The horn however only has one spade connection on it so am I missing something?
PostPosted: Mon Feb 13, 2012 8:23 am Up
The horn is probably earthed through the bolt that holds it to the chassis.
I can see a dead 206 coming up very shortly.
PostPosted: Mon Feb 13, 2012 8:34 am Up
Why do you even need a horn on a track car? Confused
Big_Rich180
PostPosted: Mon Feb 13, 2012 8:38 am Up
To beep at the girls as you drive past like a hero Laughing
Ahoward87
PostPosted: Mon Feb 13, 2012 8:41 am Up
We shall see. A couple of hot laps can't do it too much harm....... **Touches a big piece of timber**.
So one of them wires will be live and one will be for earth. So I should find out which is which and connect the live to the horn and ground the other one. As you can tell electronics are not my strong point. Wink
Ahoward87
PostPosted: Mon Feb 13, 2012 8:42 am Up
Took the words out of my mouth Wink
PostPosted: Mon Feb 13, 2012 9:18 am Up
I refer to my previous comment.
If you are not 100% sure about what you are doing, leave well alone.
PostPosted: Mon Feb 13, 2012 9:19 am Up
I don't think he means your driving. Wink
PostPosted: Mon Feb 13, 2012 9:44 am Up
I LOVE the smell of a fried BSI unit in the morning Rolling On The Floor Laughing
Ahoward87
PostPosted: Mon Feb 13, 2012 9:55 am Up
Watch me prove you wrong!,. I'm normally making things work again and getting it tip top then break my cars thank you!,!
If this car is dead in 1 year I will give Macca a crisp £20 note for being mystic meg. Wink
twitch169
PostPosted: Mon Feb 13, 2012 2:24 pm Up
Red is live and green is negtive i got steering wheel same put red on bk of the horn then put green through one off the bolt holes in ya boss then bang the wheel on
peugeot 1.6 xs lowerd with black 15\" alloys custom chrome grill painted red dash and trim
