Online Now [226]:
Visitors: 225
Today: 59092
Total: 155850260
Forums › The Car › 206 Talk › multiplexed adjusting handbrake
Forum Index › 206 Talk
craigdmjv
PostPosted: Mon Feb 13, 2012 1:56 pm Up
hi guys and girls i am going to adjust the handbrake on the cc tomorrow using this guide, it is multiplexed so if i am disconnecting the roof switches etc do i need to disconnect the battery thank you Laughing
PostPosted: Mon Feb 13, 2012 1:57 pm Up
why do you need to disconnect the battery when doing the brakes?
DeadEyePaul
PostPosted: Mon Feb 13, 2012 1:58 pm Up
Sorry enlighten me what does a handbrake cable got to do with switches?
craigdmjv
PostPosted: Mon Feb 13, 2012 2:01 pm Up
because the bsi or what ever it is and when messing with electrics sometimes you should disconnect the battery and i have the roof switch in the panel that needs to be removed so have to disconnect it Smile
PostPosted: Mon Feb 13, 2012 2:10 pm Up
well i still don't quite get it but if you wish there is no harm to disconnect the battery.
but make sure you following the bsi shut down guide
craigdmjv
PostPosted: Mon Feb 13, 2012 2:12 pm Up
if its not needed i wont bother
PostPosted: Mon Feb 13, 2012 2:16 pm Up
It is good practice....
Just leave the ignition switched OFF while the switch is unplugged.
craigdmjv
PostPosted: Mon Feb 13, 2012 2:17 pm Up
ok mate cheers
craigdmjv
PostPosted: Mon Feb 13, 2012 4:08 pm Up
how do you remove the window switches is it just unclipped the same way as the bck cover e.g. with a screw driver
