Online Now [1084]:
Visitors: 1083
Today: 111902
Total: 154802521
Forums › The Car › 206 Problems › door cards?
door cards?
marc206
PostPosted: Wed Feb 15, 2012 6:34 am Up
just bought some 180 interior, only just noticed that on the front door cards there a hole for the door lock ?thing? and the cards i have in at the mo doesn't
is there any way to fill it or something? lol
my own mistake i know
PostPosted: Wed Feb 15, 2012 6:37 am Up
Hole for the door lock?
Are you sure you don't mean the hole on the back above the solenoid? Some doors have the bracket that uses it as an extra support, if your doors don't have it just ignore it really.
marc206
PostPosted: Wed Feb 15, 2012 6:41 am Up
not sure if im being clear enough lol the little thing that sticks out of the hole when you lock/unlock it
this is what i dont have :
jimjam19927
PostPosted: Wed Feb 15, 2012 6:52 am Up
Its pretty rare to not have these. You and Andrewxps are the only people I know who have it. Pm him maybe?
Member: 685
I Over Use Smilies Razz
PostPosted: Wed Feb 15, 2012 6:55 am Up
No that wasn't what I meant, did your old door cards not have the holes? Confused
Never seen them without it before, unless someone decided to remove the linkage.
PostPosted: Wed Feb 15, 2012 8:59 am Up
Never 206's dont have door lock pins so there isnt any holes in the door cards, pretty rare find though.
marc206
PostPosted: Wed Feb 15, 2012 10:36 am Up
door cards that i have in at the mo doesnt have a hole in dno if its related to the centrol locking or something?
PostPosted: Wed Feb 15, 2012 11:10 am Up
Yours is a newer 206 so it doesnt have door lock pins fitted as Peugeot changed the design.
marc206
PostPosted: Wed Feb 15, 2012 11:18 am Up
guess i'll just fit the seats then Confused
PostPosted: Wed Feb 15, 2012 11:23 am Up
You will most likely find you could fit some matching lock pins to fill the holes if you really want, I doubt Peugeot changed the door latch design as well.
Its a metal rod with hook on one end & plastic lock pin on the other, there is a foam bit that sticks on the door to stop the metal rod rattling.
99.9% of 206's ive seen have had lock pins fitted, yours is just an odd one without them.
marc206
PostPosted: Wed Feb 15, 2012 11:41 am Up
sounds to complicated to me haha Laughing
PostPosted: Wed Feb 15, 2012 11:43 am Up
Buy a door pin and just super glue it in the hole.
Or buy a door pin with the LED fitted, so that it lights up when the alarm comes on Wink
PostPosted: Wed Feb 15, 2012 11:55 am Up
Just go down the scrapyard with a torx 20 screwdriver to get a pair of door pins, you can then see how easy they are to remove & fit to yours Wink
marc206
PostPosted: Wed Feb 15, 2012 1:20 pm Up
is it one size fits all, they can be off anything or does it have to be a 206? Razz
PostPosted: Wed Feb 15, 2012 1:37 pm Up
Has to be a 206 & choice of colour, grey or black plastic.
