Online Now [352]:
Visitors: 351
Today: 76283
Total: 128049273
Forums › The Car › 206 Problems › few problems with girlfriends car
Taff!
PostPosted: Thu Feb 16, 2012 5:20 am Up
I would say it's a connection somewhere but someone else might have a better idea.
206 1.6 Quiksilver
XSIcheeseman
PostPosted: Thu Feb 16, 2012 6:39 am Up
Cool right another thing is...... Going over bumps slowly there's something clunking around from the drivers side. I looked at the mounts theyseem ok gonna tighten the struts up tonight any other ideas?
New and Improved!
New Project
www.206info.co.uk/Foru...51199.html
Taff!
PostPosted: Thu Feb 16, 2012 6:42 am Up
I have that too.. if you find it let me know! I'm convinced it's something within the door but everything is all tight.
206 1.6 Quiksilver
XSIcheeseman
PostPosted: Thu Feb 16, 2012 6:50 am Up
Great lol I'll find the problem
New and Improved!
New Project
XSIcheeseman
PostPosted: Thu Feb 16, 2012 12:14 pm Up
Anymore ideas?
New and Improved!
New Project
Taff!
PostPosted: Thu Feb 16, 2012 12:20 pm Up
Is it more of a rattle or a clunk? I have a clunk but think that will go once the rear shocks are changed. rattles could be a heat shield, doubt it's exhaust. Check in the sapre wheel for the jack and make sure that securely located and not bouncing about in the cage. Check in the boot where the wheel brace is that it's secure and that there's no bits in there floating about.
206 1.6 Quiksilver
XSIcheeseman
PostPosted: Thu Feb 16, 2012 12:25 pm Up
It's a clunk coming from the front , I'll give it a better inspection at the weekend but just looking for ideas
New and Improved!
New Project
Taff!
PostPosted: Thu Feb 16, 2012 12:26 pm Up
stupid and easy one as sounds more like a bush but check your pollen filter. If mines lose it flaps and reverbs though body giving a thumping sound.
206 1.6 Quiksilver
PostPosted: Thu Feb 16, 2012 4:43 pm Up
Or bulb blown is just (more) as likely.
XSIcheeseman
PostPosted: Tue Feb 21, 2012 12:18 pm Up
right it didnt have a bent axle or anything just both rear shocks are knackered ........... the clock doesnt work either so im think a wire has broke or something ill take it apart when im back from trip to bristol
New and Improved!
New Project
XSIcheeseman
PostPosted: Tue Feb 21, 2012 2:38 pm Up
Well it had a new clutch to find both lower arms are hanging :/ gearbox is on its way out . Front near side shock leaking. Front brakes worn and cam belt needs replacing
New and Improved!
New Project
PostPosted: Tue Feb 21, 2012 3:14 pm Up
that cost more than the car lol
XSIcheeseman
PostPosted: Tue Feb 21, 2012 3:16 pm Up
the clutchcost 300 lol
New and Improved!
New Project
PostPosted: Tue Feb 21, 2012 3:28 pm Up
yes...but you aid you got cambelt, gearbox, dampers, wishbone and brakes as well....
you should have just gave her your XSi lol
PostPosted: Tue Feb 21, 2012 5:23 pm Up
Park it in the garage for spares and go find a good one.
Page 2 of 3
