Latest: sparrowdclxvi
Overall: 17139
Online Now [182]:
Visitors: 181
Today: 35231
Total: 113644014
Forums › The Car › Solved 206 Problems › Cigarette lighter fitting
Jammie_1989
PostPosted: Fri Feb 17, 2012 5:27 am Up
www.ebay.co.uk/itm/Cig...2996wt_836
Does anybody know how to wire the above? The connector in my car has a plug on the end with three wires. There are two other connectors with wires I could probably link it into but not sure where to start.
206 gti 180
iainlovatt
PostPosted: Fri Feb 17, 2012 5:34 am Up
first of all, there are three because, earth, live and light, get a multimeter out and find pout the positive one, there is your live, then turn on the lights, find the one that now comes on with the lights and walaa by knowing two of them help find the third one, the earth, then just wire it in, job done!
(My Garage)
Jammie_1989
PostPosted: Fri Feb 17, 2012 5:36 am Up
Thanks for the quick reply it has 4 connectors on the cigarette lighter so I'm still confused Confused
206 gti 180
iainlovatt
PostPosted: Fri Feb 17, 2012 5:53 am Up
hmm, still gte a multimeter on it to find out which is what to start with! Very Happy
(My Garage)
fatboyslim
PostPosted: Fri Feb 17, 2012 7:15 am Up
So 3 connectors on the cars plug
And 4 connectors on the cigarette lighter
As Iain says the 3 from the car would be
Live feed for the cigarette lighter
Live feed for the bulb
Common earth (negative connection for both the above)
It looks like the lighter you've got has a positive & negative feed for each
So get a multimeter and find out which is which
This may help...
IIRC the middle connector on the cig lighter is +ve and the outer body is -ve (may be wrong though so check to be sure!!)
Yes I own a CC and I'm neither gay or a hairdresser!!
Jammie_1989
PostPosted: Fri Feb 17, 2012 10:36 am Up
This may help...
Thanks for the help that sound spot on. I didn't have a multimetre so I figured it out through trial and error. I only use it for charging as I don't smoke so I just installed it without the pop action part connected. Might connect it at a later point but all is working for now Very Happy
206 gti 180
Ferdasyn
PostPosted: Wed Jun 19, 2013 5:37 am Up
Can anyone confirm this? Cheers.
PostPosted: Wed Jun 19, 2013 6:43 am Up
These are the wire codes from the manual. the colours may vary though
Pre plex
+ve BH23 (pin 2) (pink)
-ve M8100 (pin 1) (Green/Yellow)
Illumination V18D (pin 3) (Grey)
Multiplex
+ve AE07A (pin 2)
-ve MC20H (pin 3)
Illumination VE12A (pin 1)
Multiplex is not what you would expect. It is a common +ve which feeds the bulb and the power outlet. Where as pre plex is a common -ve.
You really need a multimeter to make sure you get the right wires as there is no guarantee that the manuals are right. Don't want you blowing something or having smoke pouring from the car as you drive along.
DREWDEN
PostPosted: Thu Jun 20, 2013 6:48 am Up
Be careful though, the light part (bulb) is not fused and runs through the bsi. The cigarette lighter is fused.
I know to my expense as i had to pay an auto elec to sort my bsi out.
206 2ltr Hdi glx 53 plate
